Author Topic: Those wire strippers  (Read 6939 times)
Offline Alex EisenhutTopic starter
  • Place text here.
« on: September 19, 2017, 12:46:48 am »
You know the kind.
Can someone explain to me why this nominally electrical tool has a screw cutter on it? I have one of these since years, they all look the same.
But what purpose does a screw cutter serve for electrical stuff?
The cutter doesn't even work well with standard screws, leaving all kinds of burrs that make the screw unusable.
I used the cutter tonight with purpose-made break-away drawer handle screws:
But like it says, it's for drawer handles. For wooden cabinets, not electrical cabinets...
Why this bizarre combination of tools?
Online xrunner
  • hp>Agilent>Keysight>???
Re: Those wire strippers
« Reply #1 on: September 19, 2017, 12:51:06 am »
I dunno why it has a screw cutter - but I've used one to cut screws and I found it works pretty well for the screw size indicated. But you really need to put a nut on the screw first so when you cut the screw after you take it out you unscrew the nut and it cleans up the threads.  :-+
The following users thanked this post: shteii01
Offline Mr. Scram
  • Display aficionado
« Reply #2 on: September 19, 2017, 01:03:00 am »
That works, but I still wouldn't recommend that method if you can avoid it. The resultant thread isn't quite as reliable as you'd like.
  • Place text here.
« Reply #3 on: September 19, 2017, 01:27:26 am »
Well, I suppose the only reason it has a screw cutter is that it's the only tool with a long handle to begin with. You'd never be able to cut a screw by hand if there wasn't a long lever.
After 30 years of wondering, I answered myself.
Yay.
Offline IanB
« Reply #4 on: September 19, 2017, 01:32:36 am »
The screw cutter is specifically designed for the sizes of screws commonly found on electrical boxes and cover plates. Sometimes the supplied screw is too long and you need to shorten it.
If you screw the screw into the threaded hole in the cutter before cutting it to length, then when you unscrew the screw the burrs left by cutting are automatically re-formed to the thread profile, leaving the screw usable. For this to work, you must of course insert the screw in the right direction so that unscrewing it will feed the cut end back out through the threaded part of the hole.
It does work, I have tried it.
Online xrunner
« Reply #5 on: September 19, 2017, 01:35:10 am »
Well I'm not to old to learn a better way - inquiring minds want to know, how would you do it?  :-//
Offline sleemanj
  • Professional tightwad.
« Reply #6 on: September 19, 2017, 01:40:04 am »
The screw cutter is the only reason I keep one of those handy.  They do leave a pretty sharp edge though even when used correctly as above, i find it's best to debur the cut with a quick rub on a sharpening stone.
  • Place text here.
« Reply #7 on: September 19, 2017, 01:41:51 am »
The strippers I worked with... wait, let me rephrase that. The wire strippers I've worked with were always made of some sort of soft, garbagey mild steel that didn't stand up to much use.
Maybe I just got the garbagey ones. But it does work OK on the break-away screws.
Offline Mr. Scram
« Reply #8 on: September 19, 2017, 04:11:29 am »
The answer is probably more boring that you'd think: by using a thread cutting die. Though the nut trick might help you to get the die on properly. Put the nut on, cut the bolt, chamfer the cut end, lube things up, remove the nut and use the die to cut neat fresh threads. That should leave you a neat thread that's close to a factory one.
Just using a nut often leaves a thin bit of material on the end of the bolt or causes deformation, which sometimes causes the bolt and nut to bind and cause all sorts of unpleasantness. The die cutter is specifically made to cut things to the proper size and a useful tool in general.
« Last Edit: September 19, 2017, 04:19:02 am by Mr. Scram »
Offline Monkeh
« Reply #9 on: September 19, 2017, 04:25:07 am »
Or just use a dremel or a grinder carefully and you'll have a perfectly intact thread and a flat end.
Offline CopperCone
  • *knock knock*
« Reply #10 on: September 19, 2017, 04:38:24 am »
i got a milwakee combo thing and it kicks ass. i like the screw cutter.
Offline macboy
« Reply #11 on: September 19, 2017, 01:42:41 pm »
I've always had the same experience.
Then I discovered Klein brand. They are more pricey but not too bad. They'd still be worth it at their price. I also found a good one at Cdn Tire, and figured it was worth a shot at the sale price of $4. No screw cutter, but as a stripper and cutter for household wiring jobs, it is excellent, leaps and bounds beyond the cheapies that are included in those crimp terminal kits.
Offline 6PTsocket
« Reply #12 on: September 19, 2017, 02:32:54 pm »
You are using it backwards. Thread the screw into the threads, from the outside with the cutoff passing into the unthreaded jaw. After cutting, when you back out the screw, the threaded jaw acts as the nut to clean up the end of the thread.
Sent from my SM-G900V using Tapatalk
Offline Monkeh
« Reply #13 on: September 19, 2017, 02:34:00 pm »
Not very well.
Offline 6PTsocket
« Reply #14 on: September 19, 2017, 02:36:59 pm »
I have no idea what you guys are talking about. I have used these tools to shorten screws for 40 years and never had a problem. It allows for very exact thread length adjustment. What is the alternative? Do you prefer a hacksaw or a Dremel cutoff wheel and a nut?
Offline Gyro
« Reply #15 on: September 19, 2017, 06:49:06 pm »
The only reason I still keep mine (also about 40 years old) on the shelf is for the screw cutting function - they still cut screws cleanly. I've long since acquired superior alternatives for all of the other jaw functions.
The screw sizes on mine are of Metric. The OP's photo shows US thread sizes on the cutters, which are coarser. Coincidence?
« Last Edit: September 19, 2017, 06:53:02 pm by Gyro »
Best Regards, Chris
Offline IanMacdonald
    • IWR Consultancy
« Reply #16 on: September 19, 2017, 07:29:39 pm »
Never trust these tools to do any kind of crimping. Often the wire just falls out.  :palm:
Offline Monkeh
« Reply #17 on: September 19, 2017, 07:32:29 pm »
When was the last time you used an imperial machine screw?
When was the last time an American electrician used a metric one?
Offline AF6LJ
« Reply #18 on: September 19, 2017, 07:36:58 pm »
If you have the right terminal, for the right size wire, and it matches what the tool can crimp, you are going to find it hard to mess up....
They work great.
As for the screw cutter, that works great also, the threads won't be damaged....
What I find shoddy....
Is the stripper, I wouldn't use one of those if it was the only wire stripper around.
I'll use my blue point stripper or my Teledyne Strip-All
Sue AF6LJ
Offline Mr. Scram
« Reply #19 on: September 19, 2017, 07:55:05 pm »
I've posted the alternative in my earlier post :) The point was that a nut is not intended to cut threads, but a die cutter is.
« Last Edit: September 19, 2017, 08:31:23 pm by Mr. Scram »
Offline Gyro
« Reply #20 on: September 19, 2017, 08:21:18 pm »
Sorry, in the edit I completely messed up the context of what I was trying to say.  :palm:
What I meant was that the people who were complaining about the cut quality were mainly from North America (coarser screw threads). I was wondering if the different threads would affect the cut quality. The finer metric threads would hold the screw straighter and maybe improve to shear quality.
Best Regards, Chris
Offline Monkeh
« Reply #21 on: September 19, 2017, 08:22:41 pm »
Sorry, in editing I completely messed up the context of what I was trying to say.  :palm:
Oh, I've used several examples which make a complete, total, and utter mess of metric screws, that's not the problem.
Offline Gyro
« Reply #22 on: September 19, 2017, 08:42:53 pm »
I guess they just made them better 40 years ago then.  ;)
Best Regards, Chris
Offline rdl
« Reply #23 on: September 19, 2017, 09:00:10 pm »
Like so many other things.
Offline IanB
« Reply #24 on: September 19, 2017, 09:48:46 pm »
Actually, the threads used on the screws for electrical boxes and faceplates in America are quite fine pitched, typically 24 or 32 tpi if I remember correctly.
