I have a UNI-T UT61C and the EXTECH EX330.
I needed a couple of new meters and decided that they should have uA reading capability.
The EXTECH won Dave's $50 shoot-out, that and the built in NCV - Non Contact Voltage detector swung the choice on that one.
The EXTECH 330 came with the battery/fuse cover screw missing and an o/c thermocouple.
I sent it back at my expense and two weeks later the replacement arrived, after a bit of email chasing.
The replacement EX330 had an intermittent fault on the NCV.
Suspecting dirt particle/s under the switch I kept at it and eventually it seems to have settled into an operational state, fingers crossed.
Except it's reporting a voltage on walls with no power running through them. Not all walls, just some.
I don't know whether it's down to the moisture content of the walls or what.
It even kicks off on a door handle mounted in a wooden door.
I decided it wasn't worth the hassle and cost of sending it back again so I'll live with it as it is.
The rest of the meter's functions appear to be OK but I can see that I'll have to do some comparative tests before I can trust it further.
It's a nice little meter but QC doesn't seem to be EXTECH's strong suit.
The UNI-T UT61C has given me no trouble at all.
I haven't tried the RS232 link yet.
I do wish now I had got the RMS D version, I hadn't noticed that difference when weighing up the features of the A,B,C,D & E models.
I DID want a thermocouple function though.
I'd recommend the UNI-T over the EXTECH.
