I have no idea.
Why are you asking? Are you considering upgrading to Windows 10 and are worried some of the programs you currently use won't work?
I use LTSpice, at home under Linux/WINE, at work under Windows 7 and occasionally at my parent's house on their PC, which runs Windows 10. I've found LTSpice performs worse under Windows 10, than any other system. It's even more stable under Linux/WINE, although it does crash occasionally.
I occasionally use Proteus at work, again under Windows 7, but not at home: I haven't done any hobby PCBs for ages and would probably use KiCAD or stay at work and do it after hours using Proteus if needs be.
My advice is don't bother with Windows 10. Migrate to Linux if you can. It's now a perfectly viable desktop OS and most problems can be easily resolved, without reinstalling it. Last night I had a problem logging in to MATE desktop after a crash: I got the "could not update .ICEauthority" when logging on. At first I thought I'd needed to reinstall, but I got out my phone, Googled the error and found a fix in five minutes: just delete the .ICEauthority file, so I renamed it, using the command like and was able to log into the desktop with no problems. This is the first such problem I've had in nearly three years of using Linux as my primary OS and it was easily fixed.
