Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
UT61E problem
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: UT61E problem (Read 2173 times)
expert92
Newbie
UT61E problem
on:
July 17, 2011, 05:33:26 am »
i am using ut61e multimeter and there is a problem when i am trying to measure an AC volt that the lcd shows up to 3 volt when i am changing the range of the multimeter (nothing connected) then it reduced to 0.3 volt then (after50 seconds ) to 0.03 then slowly to zero !
and the problem happens only with measuring AC values but when i measure an power supply for example it told me 120 volt (true value no problem) so i don't know if there is a problem with the multimeter or not
(i noticed that the value is changing very quickly when i move the cables of the multimeter)
please help !
Logged
pablo
Contributor
Country:
love electronics !!!!!!!
Re: UT61E problem
Reply #1 on:
July 17, 2011, 06:58:50 am »
that's a true RMS multimeter and in a true RMS multimeter most of the time it displays a value different from zero
which is pretty normal, doesn't matter if you got nothing connected to your test leads.
That's an offset for compensation purposes.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
UT61E problem
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
