Author Topic: Plastic Buckle?  (Read 509 times)
Offline Lord of nothing
  • Country: at
Plastic Buckle?
« on: July 18, 2017, 12:57:06 AM »
Hi
I know many people here know many products.  :-+
On a Product the Strap is to short.  :-\ I know there is an Option to gut it and replace it but I dont want to because I need it also short.
The best option is when I buy an unused pair of Buckle and some Strap and make my own replacement.
The called: utx flex m-ss-1 1/2"
I found the Company who make it: http://www.utxgroup.com and write some "distributor" who should sell it.
The webpage from the Company is shutdown and dont look good.
Does anyone where I could a genuine spare part?
Made in Japan, destroyed in Sulz im Wienerwald.
Offline ajb
Re: Plastic Buckle?
« Reply #1 on: July 18, 2017, 03:30:48 AM »
Does it have to be that exact part?  Lots of companies make those sorts of buckles.  Just searching for "1.5" plastic buckle" brings up several options on Amazon, etc.  Adding the term "webbing" instead of strap may help.  You could also try an outdoor supply store, they often sell replacement buckles for backpacks and such (in the US, this would be REI or Hudson Trail, for instance).
Online rstofer
Re: Plastic Buckle?
« Reply #2 on: July 18, 2017, 08:53:06 AM »
I'm not sure what buckle you are looking for but if it is just a 1-1/2" plastic style, here's one:
https://www.countrybrookdesign.com/buckles-plastic-flat-side-release-ykk-1-1-2-inch.html
SCUBA shops tend to carry this kind of thing.
If this is the right style, you can Google for 'ykk plastic buckle' to find other sources.
  • Country: at
Re: Plastic Buckle?
« Reply #3 on: July 18, 2017, 09:29:47 AM »
Yes!
The other part is fix mounted and cant be removed.
here's one:
Dont fit.
Sadly not its not.
