I work in a lab that uses ~ 40 PSI steam to power undergraduate experiments for a class. Steam and High Pressure Hot Water is awesome for transferring heat long distances. In our case, much more convenient then electric heaters.
Seven Kilowatts worth of energy fits through a simple 1/4" steel line for the last few feet and the safety protocols are much easier then trusting 130 students per day with taking care of three phase heating elements around a vast amount of water that is boiled for the pilot plant training.
Steve
What's the heat used for? With a name like LaserSteve you automatically get credibility in my book.
Yeah in that second video he's not even wearing gloves. Seems stupid considering lasers bounce off silver objects and once treated with the laser the metal becomes very shiny. I'm actually surprised that it works on the shiny metal, or maybe that's how they get the laser to only take off surface deposits and it stops when it get to the shiny metal.
Does wavelength play a part in what kinds of material you can cut/treat? Cool thing about organic materials is that even a piece that is clear can be cut since it breaks down into a black color, provided you have a small spec of dust to start the process going. My thought was that a silver surface was impervious to lasers. Those lasers seem purple which is how IR looks on digital cameras, so IR laser maybe? OR is it a purple/UV laser?
Since IR is basically heat and heat is what does the work in cutting I never understood why shorter colors work at cutting, often times better. MY blue laser burns a lot more then my green one and I think they are same wattage or the green one maybe even higher output wattage. Seems like red lasers don't burn at all or at least not at powers that I have seen.
