One area where these old Tek tube scopes are still useful is working with Tesla coils and similar devices. I'm not taking my DSO anywhere near one of those things but that old Tek would be no problem.
Yep. Did you notice the word "PLASMA" stenciled on the unit in a few places? What's the bet that's short for 'plasma physics department' or something like that? Some research group dealing with high voltage plasma stuff.
I'd love to get an old valve scope like this, for exactly that reason. My HP 54120T scopes have the bandwidth I want, but their maximum input limit is +/- 5V. I'm certain this is going to be a problem, no matter how conservative I am with attenuators.
Thanks for saving it.
Obsolescence is only one side, the other side is ease of operation and keeping it functional. This is where this scope shines, you can fix about everything except the CRT and everyone with a basic understanding on how to use a scope can use it. Also hard to kill by overload. Modern scopes might not be obsolete, but they are usually a nightmare to repair once broken and usually can't take much overload.
Quite similar with machines, old ones without electronics might also be obsolete, but are easy to fix, set up and operate. CNC is more capable, but evil to fix and more difficult to learn.
Totally seconded. And you forgot to list 'can get detailed paper service manuals including full schematics, theory of op and calibration procedures you can easily do at home'. None of which is true for modern DSOs.
Downsides:
* "You can fix about everything" will involve tracking down very hard to find old valves. That mostly are not made anymore, and any found may also be age-degraded.
* Most of those old carbon composition resistors will be drifted high, often well out of tolerance.
* Mass recapping probably required.
