Greetings EEVBees:
--I recieved the $9 Sargent RJ45/12 crimpers, see pictures below. These are missing the spring and arm that keeps them open, but they are more than sufficient for my purposes. These are very high quality professional crimpers, but even they do not do a perfect job every time. I have now re-crimped all my wrong and poor crimps, I bought a router switch so I can go beyond 4 taps, and I am running wire to every connection on the property, including my shed workshop. I find I have to re-crimp some joints while others must be cut off and re-crimped. Nonetheless with a little fiddling and inspection, I am able to get a very professional result. I did notice that the round cable was not being held very tightly by the plastic clamp, so started putting a piece of flattened cable behind it, so I now get mechanically sound attachment. See below the labeled pictures of various crimps.
--I am using solid RG45 Cat 5e cable, with solid wires, and the crimp-on plugs which have the two sharp points which penetrate the insulation. Should I be using a different crimp-on plug for solid wire, and if so, please give link or name of product, if you remember. Thanks Again.
"Human judges can show mercy. But against the laws of nature, there is no appeal."
Arthur C. Clarke 1917 - 2008
Best Regards
Clear Ether
