Author Topic: which forum software  (Read 1989 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« on: October 17, 2011, 10:52:43 pm »
I will possibly be setting up a forum for my local area, which forum software would be recomended, this one (simple machines) seems good, can it be fresh installed ? I don't think my host has many forum options but i think most can be uploaded and installed can't they ? (I have done it before). I am not really in the mood for another spell with phpBB as i used it before and frankly it was a maze and a mess to administer.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline amspire
Re: which forum software
« Reply #1 on: October 17, 2011, 11:09:28 pm »
If your host is Cpanel based and they have an icon for Fantastico, then it probably has SMF under discussion boards.
If so, install just takes settings seconds.
If not, Simple Machines is designed to use minimum server resources, so you should be able to manually install it without needing help from the hosting company.
Richard.
Offline Simon
  • Global Moderator
« Reply #2 on: October 17, 2011, 11:39:43 pm »
it is not Cpanel based, I'll probably do a fresh install
Offline Chet T16
  • Country: ie
    • Retro-Renault
« Reply #3 on: October 18, 2011, 02:36:28 am »
Are you looking for free?
I upgraded my forum from phpbb to vbulletin a few years ago and haven't looked back.
Most, if not all, only require adding a database, editing the config file to suit and uploading
Chet
Paid Electron Wrestler
Offline MrPlacid
  • Hobby Hobbyist
« Reply #4 on: October 18, 2011, 03:48:02 am »
Simon,  last year I copied my smf folder straight to my server's (even though they had cpanel and smf ::)). Then, I recalled, clicking on an installation file and it configured everything. After that I deleted the installation file. That was it.
That said, I love those more expensive forums ;D
