In my country, where we care a bit about safety, the 'old tube sets' are a major reason why we have polarised plugs, people used to electrocute themselves.
Didn't stop people wiring plugs wrong though so the first check for every new repair job on an item where there was a rewireable plug was to open the plug and make sure it was fitted properly, safely and had an appropriate fuse.
There were a rather shocking (intended) number that were dangerous, wires stripped back too far so conductors were exposed, fuses wired out or wrapped in aluminium foil, 15 amp fuses for a device that only needed a 3 or even a 1 amp fuse, wires splice by twisting together and 'insulated' with sellotape, loose screw terminals, no strain relief, all sorts of horrors.
