If you want your Gazillion Core gamers or normal Windows PC to perform like a snail crawling backwards uphill,
or a cat chasing it's tail stuck in a restart loop,
be sure to play the 'auto update' game 24/7.
Switch the sucker off and do manual SEARCH FOR UPDATES and see what's available to download and install, including Optional updates for drivers and software etc. ONLY if you need them.
Don't update something just because it's there or it's the latest version.
If your PC is working ok don't download anything unless you are absolutely SURE you need it,
because the update (and the update for that update lol) may screw up your PC real good.
Add a bully anti-virus program/s to that PC mix update with its own auto updates (and constant scare notices to do so
) and you are inviting the beginning of constant computer nightmares, and Mac beachball performance
If you're really paranoid and buy into mainstream computer FEAR tactics,
then back up your data,
perform a clean install,
kill auto update,
check for updates,
select all of them including the Optional ones too,
download the lot, restarting on the prompts,
then a proper defragmentation to sort out the mess, and that may take a few hours!
Once complete, you should be good to go on the next restart and be fully updated, proud and safer in your mind
Or you can play with Linux while Windows is undergoing renovations, and see how the other half surfs
