but ultimately, it's a place to play football, cricket, etc.
It's a place to watch others play... Meh, I'd rather do than watch, which makes having CFS really suck. Heck, I don't even have the energy to watch TV anymore.
Thumb their noses at nay-sayers, of course!
LOL you're adorable! It's like listening to kids fantasize about themselves as adults. Cute, until you realize you guys are in your forties.
I'm older...
It's no fantacy, no pipe dream, but instead a hope for the future.
I guess I'll post this. I wrote it up earlier and didn't post it because the conversation had moved on..
I'd suggest that bitterness is going out of your way in an attempt to spoil other peoples dreams. Why else would you spend so much energy on this topic?
Because there are thousands of dreams that are actually worth dreaming. Your time on the mortal plane is limited. How about working out how to make this planet work out for the species that's already here?
Instead of pretending to care about some nebulous future? Is it because you know it will never happen therefore you don't have to work at it? You know, like praying?.
I don't think you can understand the level of frustration I have with current society. At a job I'd get a string of outstanding performance reviews from my directly above managers, then I'd get fired because the big boss didn't want a queer on staff. Again, and again, and again this happened. I'm well past the point where I can deal with that BS anymore. All of that and the other ill treatment that I've received over my life has left me disabled. For me the future will hopefully be much better if I survive that long. There has been a slow but steady increase in the acceptance of queers in society. It's finally starting for transgenders like myself, but it's likely to late for me. I'm physically and mentally broken and can't stand going out of the house anymore. My endocrine system is worn out and failing because I spent to much time in fight or flight mode* when I was young. Even if I psychologically could work, my failing endocrine system won't let me. I have so little available energy production capacity left that I can't even spend an afternoon thinking to my full potential. Just an hour of deep thought leaves me exhausted with a severe headache and nausea. Then I have to take a many hour break to rest my mind, and let it recharge. Watching TV or listening to the radio is out. They use energy. I often just close my eyes, meditate on calm images, and try not to slip into deep thought, or go and post on the net. It takes very little of my mental capacity to read and post on forums.
* really Fight, Flight, Freeze, or Faun mode. Fight or flight is to simplistic and doesn't cover all the ways one can cope with potentially threatening situations.
Strange, I still don't see any Moon bases or Mars vacation colonies. Seems to me it's you who needs to accept you aren't right.
At the end of the Apollo era space travel was only in the nation state affordability zone, despite that some mega millionaires and billionaires were still thinking about it and exploring ideas. They just didn't have the money to commit to as an expensive of project as going to the moon or Mars looked like it would have been. Musk is managing to greatly reduce the transportation cost bottleneck. Once Musk has fully reusable rockets, actual launch costs per ton will be less than 100th of what they were in the Apollo era. He's getting it down into the cost range expected for space elevators.* His per ton Mars transport costs will be well less than 5% of what NASA projected, but the cost of the habitats will be more because they are designed to be permanent. The last design I've seen looked to be a stackable dome type structures that can be covered with regolith for solar storm radiation protection. NASA wasn't giving the visiting astronauts much more than a lunar lander module and some tents to live in. Musk's stated goal is $200,000 per person for what I assume is a 1 way trip to Mars. Even at 10 times that rate, I could sell the farm, visit Mars, and still have a very nice nest egg to retire with. Corporations and governments will see that as a bargain.
* Space elevators are a cable running from ground to way out past geo stationary orbit. They literally are in geo stationary orbit, but are so long one end touches earth, and the other is way out in space. You can balance the ground end with a weight at or out past geo stationary orbit. We can make the extremely strong carbon nanotube fibers needed to make them, but as of a decade ago there wasn't a glue strong enough to bind them together. Last I knew they needed a glue that was another 10x stronger. Don’t worry, that is being worked on. The BFR in one shot use mode would be powerful enough to loft a starter section of cable into geo stationary orbit. Once unreeled with it's earth end anchored on earth, they could thicken it to the strength needed for carrying loads up by sending cable layers that glue on additional strands starting in orbit, and going both down and up at the same time. This way the cable remains balanced in weight around it's geostationary orbit point. After it is heavy enough, then cable layers can start at ground level and go up. Eventually traffic up and down will need to be relatively balanced, or the counterbalance weight needs to be sized for the difference in traffic weight. Loads would climb the cable rather than being pulled up. The cable close to geostationary orbit will be thick and wide, but down at ground level a flat ribbon a meter wide and a few centimeters thick is all that is needed for starting 100 ton climbers going up. Multiple loads could be climbing or descending at once. There are some big technical issues needing to be addressed. Stuff like it maybe would ground out the Van Allen belts, and be a big lightning rod. Carbon nanotubes are an excellent conductor, but can also be made resistive. Yes, you can make integrated circuits with them. To have loads going both up and down at the same time would require some sort of tracks. Right now the plans call for the cable to be a flat ribbon and grip wheels will press on it from both sides. Power to the climber will needed to be provided somehow from the ground and geostationary orbit. The advantage of a tracked cable would be power from slowing descending loads can power ascending loads. On the other hand it is much more complex, and needs to be a lot bigger to support the track structures, and associated equipment. My expectation is ribbon cables first, and track ones later after mining the asteroids provides enough materials.
I don't think you got a single thing right in that statement. Trying to fit us all into the same pigeonhole is just your way of insulting the world.
Could just be a lazy binary way of dealing with the world that many have. For me, I deal with all the hues, saturations, tones and shades out there. Binary thinking with old opinions not being reevaluated when new data comes to light does not compute for me. When new data is learned, my opinions will be reevaluated and may change.
