Author Topic: accessing libraries to edit components  (Read 1792 times)
Online Simon
  • Global Moderator
    • Simon's Electronics
« on: January 16, 2018, 03:16:02 am »
Having installed my own libraries as recommended by CS support I find that the only way to open a library to add/remove/edit parts/symbols is by double clicking on the library file. However it seems that once i have opened and even after closing again I can't open the folder. So how can I access the library from the program for editing? this is very strange as I have had no problem opening my library folder before.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
