Author Topic: Anyone running with vbox under a non-windows host (e.g. linux)?  (Read 1228 times)
Offline evb149
I'm starting to evaluate it but thought I'd save the hassle of setting up a new machine by trying it under VB on my general LINUX dev. machine but it seems like there's what looks like it could be a DirectX / Shader model 3 compatibility problem with the setup where the symptoms are that the example schematics render / view OK but the PCB totally fails to render / view (black subwindow) for the PCB board and library examples.
Is anyone aware of a work-around or can confirm success with maybe some different host GPU driver / kernel or VB version or guest setup?
I tried all the guest addition 2D / 3D enabling and display options and nothing seems to help, though maybe a newer VB version could help though I don't see anything encouraging in the changelogs and there are still Shader Model 3 guest passthrough compatibility bugs listed from 5 years ago that haven't been "CLOSED".....
I guess CS has not got some of the DirectX use control settings that full AD had / has unless I'm missing something available in the features / settings.
VMWARE claims to have DX + SM3 support maybe that'll work...?
Or maybe I should just invest the time and set up a bare metal sandbox to use with it though windows...ugh.
Offline ebclr
Re: Anyone running with vbox under a non-windows host (e.g. linux)?
« Reply #1 on: June 04, 2017, 04:17:42 PM »
On my hardware, VMware runs very nice on Ubuntu as the host and  also on another machine as Windows 10 host
The following users thanked this post: evb149
Offline lty1993
  • Country: cn
    • LTY's Space
« Reply #2 on: June 21, 2017, 12:02:47 PM »
CS works fine in VBox on my Arch Linux.
Which graphic card and driver did you use on your host machine?
Offline thermistor-guy
« Reply #3 on: June 21, 2017, 12:51:15 PM »
FWIW, I run a win7 guest under virtualbox on a Linux Mint 17.0 host. I had problems with a mechanical CAD package on the win7 guest - it wouldn't display properly. Gaming s/w tends not to run on it either. My guess is that the virtual graphics card on the guest just doesn't provide what CAD and gaming s/w need.
So I installed win7 on a separate HDD on the same PC. When I need to, I select native win7 during boot-up.
Online Naguissa
    • Foro de electricidad, electrónica y DIY / HUM en español
« Reply #4 on: June 21, 2017, 03:49:53 PM »
I use VB on Gentoo Linux from time to time with no problem. As said before, witch graphics driver are you using on host?
Enviado desde mi Jolla mediante Tapatalk
