Author Topic: Output generator broken  (Read 4160 times)
Offline mrtnTopic starter
« on: April 17, 2018, 11:59:50 pm »
I manually deleted the output files so that I wouldn't mix up old vs. new files. CS won't generate new files because it can't delete the old ones.  :palm:
Offline Kaziq
Re: Output generator broken
« Reply #1 on: August 07, 2018, 12:54:53 pm »
I have a double facepalm for you:
- I tried to generate the outputs (for the first time) - it showed "Validation failed" (no info where it failed).
- so I fixed the DRC errors (left them before, because they were not important),
- still Validation failed,
- I tried to fix all ERC errors too (there weren't any, so I fixed all warnings at least),
- then I tried to determine which output fails, so I disabled everything except for the BOM,
- it generated the Gerbers succecssfully - even the disabled ones!
:palm: :palm:
