Author Topic: Bringing drawing format into a PCB from a dxf or dwg file.  (Read 1114 times)
Online ahbushnell
« on: October 31, 2017, 01:02:08 am »
In CS, I'm trying to import a dxf file into to a pcboard mechanical layer.  When I import it change the board dimensions.  Suggestions?
Thanks
Andy
Offline negativ3
  • Country: th
Re: Bringing drawing format into a PCB from a dxf or dwg file.
« Reply #1 on: October 31, 2017, 02:44:26 am »
During import, you need to tell CS which units the file is in, see attached.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #3 on: October 31, 2017, 11:26:43 am »
DXF is a truly terrible format for data interchange.
Day Job: Mostly LEDs
Online ahbushnell
« Reply #4 on: October 31, 2017, 11:47:04 am »
The format is in Visio.  Any suggestions how to avoid DXF/DWG?
CS should let me paste from Visio.
Thx
Andy
