Author Topic: Bulk change?  (Read 3504 times)
Offline onesixrightTopic starter
Bulk change?
« on: April 28, 2017, 06:57:32 am »
Anyway to do bulk changes?
For example, I want to change the length of a bunch of PIN's. I can select them, but changing the value only changes a single pin.
Thanks!
Offline voltsandjolts
Re: Bulk change?
« Reply #1 on: April 28, 2017, 08:23:27 am »
"View" Toolbar > "Inspector"
The following users thanked this post: trevwhite, onesixright
Online tszaboo
Re: Bulk change?
« Reply #2 on: April 28, 2017, 08:58:20 am »
Step 1. Upgrade to Altium designer
Step 2. Press V;W;P;L
Online hammy
Re: Bulk change?
« Reply #3 on: April 28, 2017, 11:14:37 am »
There is online documentation available for CS. The PCB Inspector is described as well:
http://documentation.circuitstudio.com/display/CSTU/PCB_Pnl-PCBInspector((PCB+Inspector))_CS
The following users thanked this post: negativ3, onesixright
Offline JamesH-AltiumOfficial
Re: Bulk change?
« Reply #4 on: May 09, 2017, 02:04:39 am »
Hi onesixright,
In the schematic library editor, select all objects in the part by pressing Ctrl+A, then press F11 to open the Inspector. Filter to only show Pins by setting the Inspector to Include only Pins.
Change the length and click out of the Length field and then the pins in that part will change length. Please see attached screen capture, changing pin length for part C of the FPGA.
To change another Part in the component, click the part such as Part B, then click on the editor background twice to deselect so that the inspector is empty, then press Ctrl+A again to select the objects in that part and change those pins in the Inspector panel.
P.S.
The example SpiritLevel project I'm using in my screen capture can be downloaded here: https://www.dropbox.com/s/93ryocdcu8w5b3n/SpiritLevel-SL1_CS.zip?dl=0
Best regards,
James Harriman
Altium
The following users thanked this post: trevwhite, onesixright, DIPLover
