Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Circuit Studio
[SOLVED] Global editing of vias
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: [SOLVED] Global editing of vias (Read 3871 times)
negativ3
Regular Contributor
Country:
on:
August 16, 2017, 06:48:59 am »
Hi all,
Is there any way to globally edit via dimensions? I want to modify the outer diameter a touch of roughly 50ea in a design.
Or am I stuck editing one-by-one?
Thanks
Last Edit: August 16, 2017, 07:33:53 am by negativ3
Logged
voltsandjolts
Supporter
Country:
Re: Global editing of vias
Reply #1 on:
August 16, 2017, 07:28:58 am »
http://documentation.circuitstudio.com/display/CSTU/PCB_Pnl-PCBFilter((PCB+Filter))_CS
For example:
In PCB filter select object=via
In PCB editor window select all 'filtered' objects by pressing Ctrl-A
All vias are now selected
Now open the Object Inspector - change properties as you wish.
Logged
negativ3
negativ3
Regular Contributor
Country:
Re: [SOLVED] Global editing of vias
Reply #2 on:
August 16, 2017, 07:39:10 am »
Thanks voltsandjolts, perfect.
Logged
taydin
Frequent Contributor
Country:
Reply #3 on:
August 27, 2017, 01:23:13 pm »
I am trying to create a PCB footprint for a transformer and I can't find the PCB filter for selecting all of the pads. Does this filter not work when in library mode?
Logged
Real programmers use machine code!
My hobby projects
http://mekatronik.org/forum
T3sl4co1l
Super Contributor
Country:
Expert, Analog Electronics, PCB Layout, EMC
Reply #4 on:
August 27, 2017, 08:42:13 pm »
PCBLib Filter Panel works just fine with the same queries (IsVia, IsPad, etc.).
Logged
Seven Transistor Labs, LLC
Bringing a project to life? Send me a message!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Circuit Studio
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
