Author Topic: [SOLVED] Global editing of vias  (Read 1108 times)
Offline negativ3
  • Country: th
« on: August 16, 2017, 04:48:59 pm »
Hi all,
Is there any way to globally edit via dimensions? I want to modify the outer diameter a touch of roughly 50ea in a design.
Or am I stuck editing one-by-one?
Thanks
« Last Edit: August 16, 2017, 05:33:53 pm by negativ3 »
Offline voltsandjolts
Re: Global editing of vias
« Reply #1 on: August 16, 2017, 05:28:58 pm »
http://documentation.circuitstudio.com/display/CSTU/PCB_Pnl-PCBFilter((PCB+Filter))_CS
For example:
In PCB filter select object=via
In PCB editor window select all 'filtered' objects by pressing Ctrl-A
All vias are now selected
Now open the Object Inspector - change properties as you wish.
The following users thanked this post: negativ3
Offline negativ3
  • Country: th
Re: [SOLVED] Global editing of vias
« Reply #2 on: August 16, 2017, 05:39:10 pm »
Thanks voltsandjolts, perfect.
Offline taydin
  • Country: tr
« Reply #3 on: August 27, 2017, 11:23:13 pm »
I am trying to create a PCB footprint for a transformer and I can't find the PCB filter for selecting all of the pads. Does this filter not work when in library mode?
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: August 28, 2017, 06:42:13 am »
PCBLib Filter Panel works just fine with the same queries (IsVia, IsPad, etc.).
Seven Transistor Labs, LLC
Electronic Design, from Concept to Layout.
Need engineering assistance? Drop me a message!
