Author Topic: moving multiple pads in a PCB library footprint  (Read 3052 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: November 23, 2017, 01:29:57 pm »
I am making one part from another as they are near identical but have been moving pads around. Now you would think that to move more than one pad at a time you simply select the ones you want to move and well move them. But apparently not. I cannot find any way to simultaneously move a number of items in a PCB footprint. Is this really the case ?
Offline IanJ
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
Re: moving multiple pads in a PCB library footprint
« Reply #1 on: November 23, 2017, 06:34:35 pm »
Select multiple pads, press M and you will get a crosshair, now left click drag all selected together.
Ian.
« Last Edit: November 23, 2017, 06:36:37 pm by IanJ »
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
Offline IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #2 on: November 23, 2017, 07:38:05 pm »
Thinking about this, I think I mentioned to Altium way way back that the MOVE & DRAG defaults as well as the operation needed a bit of work. Coming from Eagle it was all too easy just to select a bunch of parts including traces and simply move them around and have the connected traces rubber band maintaining connectivity.......but this isn't the case so easily with CS.
Ian.
  • Global Moderator
« Reply #3 on: November 23, 2017, 07:40:03 pm »
Yes CS does have some pretty weird things.
