Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Circuit Studio
importing eagle 5 files into CS
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: importing eagle 5 files into CS (Read 2905 times)
Simon
Global Moderator
Country:
Did that just blow up? No? might work after all !!
on:
November 20, 2017, 03:28:23 pm »
I am designing a new PCB that will sit with some units designed by a subcontractor using eagle 5. Now it becomes obvious that putting the other 2 units onto the same PCB would mean 1 PCB and not 3 and a lot of cost saving (PCB tooling and PnP setups). I have tried importing his PCB files but CS seems to want a project file whereas I think with this version of eagle it only has a schematic and PCB file. Is there a way of doing this ?
Logged
negativ3
Regular Contributor
Country:
Re: importing eagle 5 files into CS
Reply #1 on:
November 20, 2017, 03:39:33 pm »
Have you run the addon to allow importing?
Default dir: C:\Program Files (x86)\Altium\CS\System\Installation
TeighaX_Setup_3.9.0.msi
Logged
Simon
Global Moderator
Country:
Reply #2 on:
November 20, 2017, 03:49:29 pm »
I have the eagle importer installed, is this an additional one? or am I doing something wrong in the import?
Logged
negativ3
Regular Contributor
Country:
Reply #3 on:
November 20, 2017, 03:51:32 pm »
If you haven't run this addon, it won't work. After that you should be able to import SCH, BRD and LIB files from Eagle.
Logged
IanJ
Supporter
Country:
Full time EE & Youtuber
Reply #4 on:
November 21, 2017, 11:47:17 am »
I believe CS requires Eagle files to be version 6 or newer. Version 5 are binary files whilst V6 onwards are XML.
So you need to open the V5 file in Eagle 6 or later and re-save.....then should import into CS just fine. BRD and SCH files.
Ian.
Logged
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website -
www.ianjohnston.com
YT Channel (electronics repairs & projects):
www.youtube.com/user/IanScottJohnston
, Twitter (X):
https://twitter.com/IanSJohnston
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Circuit Studio
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
