Author Topic: moving multiple pads in a PCB library footprint  (Read 1251 times)
Offline Simon
  • Global Moderator
    • Simon's Electronics
« on: November 24, 2017, 12:29:57 am »
I am making one part from another as they are near identical but have been moving pads around. Now you would think that to move more than one pad at a time you simply select the ones you want to move and well move them. But apparently not. I cannot find any way to simultaneously move a number of items in a PCB footprint. Is this really the case ?
https://www.simonselectronics.co.uk/shop New stock now in of EEVblog 121GW and Brymen 235 Now selling a selection of Probe Master probes.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline IanJ
  • Country: scotland
  • Pro EE guy many years ago, now a hobby/home biz.
    • IanJohnston.com
Re: moving multiple pads in a PCB library footprint
« Reply #1 on: November 24, 2017, 05:34:35 am »
Select multiple pads, press M and you will get a crosshair, now left click drag all selected together.
Ian.
« Last Edit: November 24, 2017, 05:36:37 am by IanJ »
Ian Johnston
www.ianjohnston.com
Manufacturer of the PDVS2
Offline IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #2 on: November 24, 2017, 06:38:05 am »
Thinking about this, I think I mentioned to Altium way way back that the MOVE & DRAG defaults as well as the operation needed a bit of work. Coming from Eagle it was all too easy just to select a bunch of parts including traces and simply move them around and have the connected traces rubber band maintaining connectivity.......but this isn't the case so easily with CS.
Ian.
Ian Johnston
www.ianjohnston.com
Offline Simon
  • Global Moderator
« Reply #3 on: November 24, 2017, 06:40:03 am »
Yes CS does have some pretty weird things.
