Author Topic: new searching problems  (Read 1174 times)
Online Simon
  • Global Moderator
    • Simon's Electronics
« on: July 25, 2018, 05:22:27 pm »
So after much discussion about the malfunctioning of the search function in CS, now it has a new random behaviour: it won't work on schematics..... Only PCB's. How a program that has not changed exhibit different behaviours? This is a total joke.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Offline Kaziq
Re: new searching problems
« Reply #1 on: August 07, 2018, 07:52:49 pm »
I had the same problem - the top search bar was showing only PCB components, but I found out that the Tools->Find command worked decent.
Then after some time I wanted to search a PCB component from the top bar, and it started showing schematic components too. Weird.
