Author Topic: Rectangle vs Polyline (schematic symbols) ?  (Read 1083 times)
Offline onesixright
« on: April 29, 2017, 05:55:12 am »
Hi All,
Another question  :-[
Are there any "rules" when to use the polyline (as a rectangle) and when to use the rectangle when creating custom components (schematic symbols)?
For example: creating a relay, not sure what to choose for the "box" around the component?
And once again, thanks!
« Last Edit: May 02, 2017, 01:43:31 am by onesixright »
Offline PicoSD
Re: Rectangle vs Polyline ?
« Reply #1 on: May 02, 2017, 01:39:07 am »
Assuming you're talking about the schematic symbols:
I personally prefer to use the rectangle for ICs that have no internal structure visible on the schematic (only pins).
For components like relays where there's internal detail, the rectangle looks weird because the internals have to be drawn with a polyline which have rounded edges. So I draw the rectangle around it with a polyline too.
As far as actually using the components on a schematic, it makes no difference to CS.
You can always browse the vault and see how similar components were drawn.
Offline onesixright
Re: Rectangle vs Polyline (schematic symbols) ?
« Reply #2 on: May 02, 2017, 02:24:24 am »
Hi PicoSD,
Thanks.
Yes I was referring to the schematics (updated the question). Its probably just a matter of taste. But as there is this "rule of thumb" to draw current flow from left to right, i thought (hoped) there is also some rule of thumb for designing these symbols.
For example, I draw this simple relay, two versions. TBH i don't like either one  :-[
« Last Edit: May 02, 2017, 05:10:33 am by onesixright »
Offline PicoSD
« Reply #3 on: May 02, 2017, 05:09:09 am »
I think the second one is pretty standard, although I usually make the box blue as well. Sometimes I take a look at how Sparkfun does their schematic symbols and mimic those.
The following users thanked this post: onesixright
