Author Topic: Text block  (Read 2999 times)
Offline FrankTTopic starter
Text block
« on: July 12, 2017, 06:53:25 am »
What's the best way to create a text block on a PCB?
I need to draw a table showing what the combinations of a set of jumpers means.  Do I draw lines, then create text for each table cell?  Or should I use another program and paste an image of the table?
Thanks,
Frank
Offline tarribred61
Re: Text block
« Reply #1 on: July 12, 2017, 04:45:04 pm »
Either is OK.  If on a silkscreen layer you can't get very complicated anyway.
I tested placing an image (as a PNG format) onto a silklayer and it did OK at picking up the lines for rows and columns.  The image was generated using a screen image capture program (Screenpresso) and then saving as a PNG.  It may be a faster way to bring in a simple grid if it is complicated.
It seems like a simple table would be easier to draw as lines and text to me.
I thought maybe you could use the layer stack up table as a starter but sadly this feature is stripped from CS.  See the related thread here...
https://www.element14.com/community/thread/58130/l/stackup-table?displayFullThread=true
