Author Topic: LazerBlade: The affordable laser cutter / engraver  (Read 2641 times)
Offline snoopy
    • Analog Precision
« on: June 24, 2014, 01:15:19 pm »
Don't know if this one has been covered but it is a small CNC laser cutter for light materials.
https://www.kickstarter.com/projects/1537608281/lazerblade-the-affordable-laser-cutter-engraver?ref=home_location
It 's an aussie bloke from Melbourne. It's good to see aussies having ago. 466K raised with three days to go ;)
Offline sacherjj
Re: LazerBlade: The affordable laser cutter / engraver
« Reply #1 on: June 24, 2014, 02:45:40 pm »
Wood only < 1mm seems to be to far on the lighter materials to be useful for much.
Offline frenky
  • Country: si
    • Frenki.net
« Reply #2 on: June 24, 2014, 05:17:11 pm »
They changed laser led with one with more power. Can cut 5mm balsa and 2.8mm light plywood.
Offline Fred27
    • Fred's blog
« Reply #3 on: June 24, 2014, 07:42:36 pm »
That's not significantly cheaper that a Chinese 40W CO2 laser that is actually useful. Granted the quality control and stepper control board on the DC-K40 are suspect, but nothing the average EEVblog reader can't cope with.
