Author Topic: WiFi shield for Arduino on Kickstarter  (Read 5164 times)
Offline Emil
  • Country: no
    • ZeptoBit
« on: January 06, 2015, 11:03:19 pm »
I have made a WiFi shield for Arduino and a library to use it.
The project is open source (hardware and software). All source and design files will be published before the Kickstarter campaign ends.
The shield uses the ESP8266 ESP-03 module and handles voltage regulation for the module and level shifting between the 5V Arduino and the 3.3V module. It has two rows of holes to solder headers, one Arduino compatible and one with standard 0.1" spacing.
I'm documenting the project and the example projects I'm making using it on Hackaday: http://hackaday.io/project/3749-wifi-shield-for-arduino-using-an-esp8266-module
Kickstarter: https://www.kickstarter.com/projects/902741881/8266wing-wifi-shield
Emil
Offline zapta
Re: WiFi shield for Arduino on Kickstarter
« Reply #1 on: January 07, 2015, 12:12:59 am »
Can it do SSL? What is the binary size of a simple program that connects to a remote server over ssl and does a simple get ?
Drain the swamp.
Offline Emil
  • Country: no
    • ZeptoBit
« Reply #2 on: January 07, 2015, 12:55:32 am »
The library does not handle anything protocol specific, so you would need to implement SSL yourself. My library (or the module) doesn't do anything on OSI level 6 or 7.
I made a simple program to send a get to a http server and it was just under 8K, around half of that is the software serial library.
Emil
Offline zapta
« Reply #3 on: January 07, 2015, 02:32:47 am »
OK, so no SSL support, thanks. I found recently a Wi-Fi module from Connect One that has built in support for SSL so no much overhead on my poor atmega328p host MCU.
Drain the swamp.
Offline Stonent
« Reply #4 on: January 07, 2015, 03:26:21 am »
You can load the ESP8266 with whatever you want.  It's a wifi chip and MCU all in one.
I realize this project has a specific purpose, but I do hope someone makes a version of an ESP8266 board that resembles a .6" dip chip that can be easily breadboarded.  A 24 or 28 pin version would probably work.
Break out the ESP8266 fully on one half of the chip and on the other half, include a 3.3v regulator and use level shifters to allow for 5v logic and serial.
Offline mhwlng
« Reply #5 on: January 07, 2015, 03:36:42 am »
Something like this ?
http://www.aliexpress.com/item/NodeMcu-Lua-WIFI-development-board-based-on-ESP8266-Internet-of-things/32264797795.html
(I have no experience with this board)
Also note that none of the available ESP8266 boards have official CE/FCC certification.
« Last Edit: January 07, 2015, 03:40:12 am by mhwlng »
Offline zapta
« Reply #6 on: January 07, 2015, 03:37:38 am »
Any off the shelf SSL implementation I can load into the ESP8266?
Currently I am using this Connect One module that is more expensive but has built in SSL stack behind an AT commands interface.
http://www.mouser.com/ds/2/84/Nano-WiReach-SMT-G2-Datasheet-v1-1-2-364748.pdf
Drain the swamp.
Offline Stonent
« Reply #7 on: January 07, 2015, 03:55:10 am »
The SDK mentions SSL http://hackaday.com/2014/10/25/an-sdk-for-the-esp8266-wifi-chip/
Offline Stonent
« Reply #8 on: January 07, 2015, 03:55:47 am »
Close but maybe without the USB interface.
Offline zapta
Drain the swamp.
Offline LukeW
« Reply #10 on: January 15, 2015, 02:28:19 pm »
Something roughly like this, then. I haven't assembled it yet.
Offline Emil
  • Country: no
    • ZeptoBit
« Reply #11 on: January 24, 2015, 06:55:52 pm »
I have released version 1.0 of the library together with some example code:
http://www.zeptobit.com/8266wing/
The Kickstarter ends in 28 hours:
