Author Topic: Are you fed up with frequent failure of your phone chargers?  (Read 10007 times)
Offline tom66
  • Electronic Engineer & Hobbyist
Re: Are you fed up with frequent failure of your phone chargers?
« Reply #25 on: January 31, 2016, 07:43:12 am »
I wouldn't mind seeing a device that would stop charging my phone at 90%. This would extend the useful life of the battery with only a small sacrifice in runtime. In particular, when I use my phone in my car as my GPS navigation, I'm aware I'm killing the battery slowly keeping it at 100% while the phone is warm. It'd be much better to keep it at 75-80% there.
Offline bitseeker
« Reply #26 on: January 31, 2016, 10:55:29 am »
The phone should be able to manage this, but we aren't given such control. I've had laptops with configurable "full" level or a smart mode that would vary at what level charging would stop (90-100%) to prolong battery life. So, a software hack should do the trick.
Life is better under the TEA. ♪♩♫ Under the TEA. ♩♫
Offline tom66
« Reply #27 on: February 01, 2016, 02:52:07 am »
Well, today I turned on my S4 with 30% charge and whenever I went to launch an application the display fluttered and the phone rebooted; tried it a few more times and the same thing happened. At 90% charge it does not. Figure the battery has worn out so I've ordered a replacement -- at least you can easily replace the battery. I would like to find a custom ROM that lets you set charge level but I suspect it's hardware firmware stuff and not going to be possible.
Offline bitseeker
« Reply #28 on: February 03, 2016, 02:27:11 pm »
Yeah, I've never heard of being able to control the max charge on a phone, just on laptops.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #29 on: February 07, 2016, 07:23:50 am »
It's one of the features that will get attention when the product is from nerd for nerds. Since they'll sure know better than the people who designed the battery and the circuit.
Complete waste of developer hours imho.
Offline keethrax
« Reply #30 on: February 10, 2016, 03:35:26 am »
You don't have to "know better" you just have to have a different set of priorities.
Offline Kalidor
« Reply #31 on: February 15, 2016, 04:37:26 am »
Remember sonicable? The scammed k$566, the thing it's not working and falling apart.
https://www.indiegogo.com/projects/sonicable-the-world-s-most-advanced-charging-cable/x/10280792#/comments
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual.
Offline MrSlack
« Reply #32 on: February 22, 2016, 12:28:13 am »
I've never actually broken a phone charger or blown one up. I've had tens of the things.
Now a USB mini cable that the latch pins don't die after a week or fall to bits or crack around the strain relief would be nice. I'd buy that.
Online meeder
« Reply #33 on: February 22, 2016, 12:30:55 am »
I have never had an issue with a failing charger or micro-usb port.
If everyone switches to USB-C the last remaining problems will dissappear. In that respect Apple did it right with their lightning connector, it is a sturdy connector.
Offline MrSlack
« Reply #34 on: February 22, 2016, 12:37:57 am »
The connectors are fine but the cables aren't. I have to replace them far more often than the cheap USB micro cables.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #35 on: February 22, 2016, 06:58:34 am »
It has to be. It's part of the chassis to be able to create those docks where the connector is the only part holding the phone.
