Author Topic: Best Practices for Crowd Funding Electronic Hardware/Devices  (Read 2247 times)
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: Best Practices for Crowd Funding Electronic Hardware/Devices
« Reply #25 on: October 30, 2018, 06:22:07 am »
Just for reference, I'll list what I'm talking about here as just a link: http://kck.st/2z5hhzw
Spring contacts onto non gold-plated PCB pads seems like a recipie for trouble.
Also if you're going to this effort, it should also provide connection points for cabling to reinforce the power connections as the voltage drop along a LED strip can get significant.
Day Job: Mostly LEDs
Offline LiTTT_up
« Reply #26 on: October 30, 2018, 07:44:35 am »
Spring contacts, whether solid core or stamped sheet metal is currently the main method employed for electrical continuity between connectors & flexible LED strips. There are also the 4-pin insert variety (which are gold plated) but require the female socket to be soldered anywhere a termination connection is desired
Although there are a few connectors out there that have a sharp point which partially punctures the strips pads/layers for a better bite at the cost of some wear and tear on the strips.
Gold plating the pads on LED strips is practically unheard of in the consumer electronics world. :-- There's just not enough money in them for that. Perhaps in aerospace applications, but these strips don't sell for enough to warrant such an upgrade. If the pads wear out, then the strip gets replaced.
Unless you're talking about mixed metal reactions., although I've had white LED strips in parts of our office running for ages on the same old cheap compression pin connectors, they had a nickel allow in them if I'm not mistaken.\
Power injection is possible with LiTTTâ„¢ Snap! connectors, it's already part of the design. Pigtail connectors can be added to any connector - anywhere in the net, that is to say - at any point down the line to reduce voltage drop over long runs.
I've also got the designs of the PCBs modified sufficiently to help out a little in that regard. Thanks for the input so far, I honestly do appreciate it. It's been a fun project and we're looking to improve the design in any way that matters in the long run.
« Last Edit: October 30, 2018, 08:07:48 am by LiTTT_up »
Online coppercone2
  • Analyzing schematics 🔬
« Reply #27 on: December 27, 2018, 09:55:41 pm »
i soldered my LED light strips I did not see a point in connectors if you use reliable LEDs and a good power supply. the main failure mode is probobly gonna be cracks on the PCB anyway so your going to have to fix it while its mounted with a soldering iron
shady interconnects are a possible fire hazard. a good solder joint is probobly going to be pretty good.
https://www.digikey.com/products/en/cables-wires/single-conductor-cables-hook-up-wire/474?FV=1440045%2C10480004%2Cffe001da%2Cf80015%2Cf8001a%2Cf80009&quantity=0&ColumnSort=1000011&page=1&pageSize=25
https://www.digikey.com/products/en/cables-wires-management/heat-shrink-tubing/483?k=adhesive%20heat%20shrink
« Last Edit: December 27, 2018, 10:16:21 pm by coppercone2 »
Offline dunkemhigh
« Reply #28 on: December 28, 2018, 07:48:53 am »
Your average LED user wouldn't know one end of a soldering iron from t'other. Come to that, I am not exactly a n00b when it comes to soldering, electronics or LEDs, but I'd prefer a simple clip-on connector to make like easy (now and when it's inevitably moved). A good-looking system like this would be preferable to an indestructible but fugly lash-up. (Hmmm, can a lash-up be indestructible?)
