Thanks for the kind comments (I'm behind the project), if you've got questions feel free to let me know!
Cmon, what a gimmic this statemeng is
At least I refrained from adding GMO-free to the description ;-)
But the PCB manufacturing is quite dirty (especially the electroplating process). I highly doubt companies are going to put as much effort into separating output waste without being forced to by government regulation - it would just cost a lot more money without being able to show anything to the customer. I know Apple's
PCB supplier was hassled for example, so it's not just little fabs doing it.
I still use China for PCB manufacturing quite a bit too due to the much lower prices (so yeah I'm not a white knight here), but if possible for a lot of reasons prefer to use North-American companies. This was echoed by my assembly house, which tried using overseas PCBs a number of times, but had enough reliability issues there was no net savings.
The better control over environmental regulation is basically a side-effect of using the preferred fab for my manufacture. Of course it's entirely possible for a overseas-based fab to have better controls than a North-American one. But I would bet that two randomly picked fabs would see the overseas one with a worse track record.
Mechanical strength of SMD USB connectors is often ignored
Interestingly it seemed a lot of people don't use the through-hole/SMD combo parts. In this case I'm using one of those, which gives me a lot more mechanical strength. The prototype boards have worse strength than the production versions will have, since I haven't used proper plated slots for the legs (they are rectangular legs), just large holes that fit the legs, but with tons of extra room.
There's a slight cost increase in the production run by adding the through-hole aspect, but considering how annoying it would be to break off the micro-usb connector it's well worth the minimal extra cost!
EDIT: Edit to notify me of replies
