Hi guys. so i made this crowd finding campaign for the smart switch which i developed with Arduino
After seeing the Campaign you might have few questions so i have posted the frequently asked ones here before you see the campaign.
1. Why is this campaign so crappy quality?
A: Well i blew off the campaign budget in product development so couldn't hire a decent graphics designer and a photographer
2. Why should i use this switch? I'm pretty satisfied with my normal ON/OFF switch.
A: This switch looks pretty and can turn off and on things remotely. some might like it some might not.
3. Is this product legit?
A: Yes it is.
So where are the actual product pictures?
here you go..
So i started selling the switch on tindie.
https://www.tindie.com/products/Oriana/capacitive-touch-panel-switches-arduino-compatible/it had Zigbee/Bluetooth/Wifi
but for this campaign and the majority uses ESP WiFi modules i have mentioned only wifi. This switch uses STM32F103C8T6 + ESP8285.
I started this campaign since i have quite a few customers locally lined up for buying this product but my Chinese supplier who supplies the back housing told me that the Minimum quantity
is at least 1000Pcs.
You can easily modify the ESP8285 Firmware so that you can use different protocol to communicate and built in functions according to your needs
GitHub :
https://github.com/hatchprototype/Campaign :
https://www.indiegogo.com/projects/hatchswitch-diy-smart-switch/
