Author Topic: Kickstarter: Tiny USB 2.5W V/I controllable power supply  (Read 2172 times)
robint91 and 1 Guest are viewing this topic.
Offline dunkemhigh
Re: Live on Kickstarter: Tiny USB 2.5W V/I controllable power supply
« Reply #25 on: December 08, 2018, 06:34:45 am »
with USB 2.0 we are limited to 500mA @ 5V = 2.5W
Clearly not applicable to V1, but couldn't you use one of the off-the-shelf fast-charge chips to get 1A or more at 5V?
The following users thanked this post: zucca
Online OwO
  • Country: cn
  • OwO
« Reply #26 on: December 08, 2018, 01:57:59 pm »
Also in practice most PC USB ports are fine delivering 1-2A, and since you have the current auto-backoff feature, maybe allow drawing up to 2A by default
OwO
The following users thanked this post: Kilrah
Offline Kasper
« Reply #27 on: December 10, 2018, 06:05:35 am »
Cool idea. Nice job. You mentioned injection molding. Did you look at urethane cast, vacuum forming or off the shelf enclosures?
Offline electrodacus
    • electrodacus
« Reply #28 on: December 11, 2018, 07:30:17 am »
Just made a pledge on the naked version :)
Take a look at my current Kickstarter https://www.kickstarter.com/projects/electrodacus/solar-bms-and-digital-mppt-for-pv-electricty-and-h  and especially look at how I done the enclosure for my devices as that may be a good solution for your's also.
Your devices looks to be very small so the PCB case should work and cost about as much as the plastic molded one but look better (just my opinion about the look).
Hope your project will be successful but is not looking that great at this point in time.
Offline Kilrah
« Reply #29 on: December 11, 2018, 08:27:07 am »
+1 on that, it's mandatory to default to 500mA max, but there should be "expert" software switches to allow for 1A/2A limits since most ports since years support fast charging.
Offline brrup
« Reply #30 on: December 14, 2018, 02:16:10 am »
Many thanks to all my new supporters!
I was thinking a lot about how to increase output current.
In my opinion, USB-BC (USB Battery Charging 1.5A) and USB-PD (up to 100 W) are not that common that it would be okay to increase costs/size for people having it, especially in a first version.
My focus was on USB 3.0 that would allow 900mA but only after the device requests for it. Hope I not overlooked it, but I was not able to find a valid answer how to request 900mA when having a USB 2.0 device, all ends in conclusion that I must have native USB 3.0 support on device then.
Some of the PCs I tested here did active limiting to 500mA when using the USB 3.0 port. It depends on the Host chip, some are more tolerant. It seems to be no problem to shortly get more (I think because mobile USB hard drives need enough initial current to run).
The answer will be USB Type-C, here the concept is nice, they separated USB transmission protocol and power setup mechanism: Up to 15W, there is no need of using USB PD specification, the output current is configured by a simple passive resistor setup for both, the cable and the device. This allows using USB 2.0 together with 15W. When needing more than the 15W again, the USB PD protocol must be implemented.
Yes, I would really like to add this hidden switch to enable more power for people that know what they do, but the final hardware design does not allow this.
I calculated/simulated/tested all for 500mA now, increasing to 900mA or more would be a significant difference and requiring other components.
So sorry, you have to wait for the next version that hopefully will come one day.
Your are right, it is not looking that great for the moment. There are too many people on world, that seems not knowing about my project.
Yes, your PCB case style is really cool, never seen this before.
Good luck to you.
The truth is, I did not. There are online supplier that are focused on injection molding for smaller prototype quantity. They use aluminum molds that are much better to process automatically. When calculating the total costs for 500 samples, it ends in something between $2 and $5 for small cases. This is still a lot for something that will cost some little cents for larger amounts, but it was okay for me.
Offline Kasper
« Reply #31 on: December 14, 2018, 04:38:53 am »
That cost is not too bad then. Based on your funding goal, I figured it was higher.
Finding a small batch method could still help to reduce your goal on the next try. Going the other direction, I was recently told steel molds are better than aluminum if you plan to tune the design because steel molds are easier to weld and cut.  That advice was from my most expensive quoter though so...
Ideally your mech design can be built with any method but at the least it is nice to have 1 small batch method and 1 large batch method.
3DHubs has a lot of info on different materials and processes and will auto quote simple builds which I found really helpful when I started learning about enclosures.
    • electrodacus
« Reply #32 on: December 14, 2018, 05:11:41 am »
Good luck to you.
For how small your device is and 250 to 500pcs the PCB case may look better (I'm biased about that :) ) and cost about the same likely around 2 to $3.
Offline Kilrah
« Reply #33 on: December 14, 2018, 05:29:37 am »
To me PCB casing looks like an "amateur"/"can't afford more" solution. If he can get an injection moulded plastic case for about same price it's a no-brainer.
Too bad about the higher current capability :(
All my computers in the past years have suppported USB-BC. It's rarely mentioned but they do. Would imagine the vast majority out there does.
    • electrodacus
« Reply #34 on: December 14, 2018, 06:17:14 am »
Have you seen my devices made out of PCB ?
I think they look better than what I can do with injection molding and since they are FR4 they are also fire proof. It allows for capacitive touch buttons also at no additional cost.
Offline brrup
« Reply #35 on: December 14, 2018, 07:30:07 pm »
On of the big players for small batch series injection molding is https://www.protolabs.com/ I think. There you can upload your 3D model, and the next day you get an online offering about the costs.
The big drawback is, if you later want to order e.g. 15.000 parts, the price will be still at > $2 per part.
As I understand aright, the aluminum mold must be replaced by a new one after 15k to 30k samples, but manufacturing is > 50% faster (=lower price). Steel is much hardener, you can produce 100k or more with the same mold.
Offline grizewald
Re: Kickstarter: Tiny USB 2.5W V/I controllable power supply
« Reply #36 on: January 08, 2019, 12:21:13 am »
It's a shame that this didn't reach the funding goals, but to be honest, I didn't expect it to as the goal was unrealistic.
@brrup: Do you have any plans to still make these, despite the Kickstarter not being funded?
