Yes, this is an old thread, but since it's still the only thread concerning the 101Hero, I decided not to add a new thread for a topic with such limited interest.
I backed this campaign simply because it was the least expensive way to learn just enough about 3D printing on which to base future decisions.
I received my 101Hero with one dead motor, but fortunately I had joined a group buy for replacement motors and they had arrived before my printer, so my printer was working right away.
It has proven to be everything I had hoped it would be! So cheap and poorly built that I had to learn a ton about how to make it print halfway decently, and how to optimize designs and slicing to avoid its weaknesses.
And it has so many weaknesses. The creators are so minimally competent at business that it's amazing they were able to ever ship anything.
The delta mechanical design is just about what you'd expect for a printer than needed to have a COGS under US$30. Lots of flex, lots of slop, terrible accuracy, but basically functional despite all that.
Their customer support is pretty much non-existent, but the 101Hero community has filled much of the need, completely independent of the manufacturer.
Despite using the Open Source Marlin firmware, they have yet to release their config files, meaning I haven't been able to make some of the tweaks needed to smooth some of the printer's rough edges.
One good thing with a printer that runs at 1/10th the speed of a Prusa i3 clone is that you can get away with using even the cheapest filament. In other words, there is no reason to put expensive filament into such a cheap printer. I'm using only those PLA filaments I can get for under US$20/kg total cost, delivered.
I've made a few mechanical tweaks. First, I added rubber bands around each pair of pivots to take up the amazing amount of slop in the ball joints. It works great, but it is important to not make them too tight, or binding can result.
Second, I slid acrylic panels between each of the pylons to stiffen the wobbly structure. It mainly helped on designs that had the extruder doing more traveling than printing, such as for parts with multiple separated vertical structures, such as the legs of an inverted table.
Bottom line, I have no regrets whatsoever getting this printer for a delivered price of US$80.
But after only 5 months of use, I've grown bored with prints taking overnight. So I backed the $99 BuildOne printer campaign by Robotic Industries to gain experience with a much faster and more capable Cartesian printer.
