Author Topic: Phone-charging belt with flexible batteries  (Read 8340 times)
Offline polar8Topic starter
« on: November 26, 2014, 02:04:39 am »
https://www.indiegogo.com/projects/xoo-belt-by-nifty-a-phone-charging-belt
Any idea what kind of battery they're demonstrating?
Re: Phone-charging belt with flexible batteries
« Reply #1 on: November 26, 2014, 02:07:37 am »
Demonstration of the lipo:
Offline miguelvp
« Reply #2 on: November 26, 2014, 03:42:20 am »
Audio is annoying to the point I had to stop watching that video.
Offline johansen
« Reply #3 on: November 26, 2014, 05:38:20 am »
and what happens when it catches on fire..  :-DD
Offline ConKbot
« Reply #4 on: November 26, 2014, 12:25:13 pm »
http://www.powerstream.com/thin-lithium-ion.htm
In the 0.6mm thickness, looks like they get 2.17 mAH/cm^2. So ~3.5 cm wide  by ~70 cm of usable space in a belt that isnt going to get pinched in the latch, 85cm or more if they have a latch which grips the edge or something where it wont damage the battery.  Works out to 531 mAh/layer for the short battery, 645mAh/layer for a thicker battery.  So call that 4 layers to reach 2100mAh either way, 2.4mm thick of battery, 2mm of leather either side makes for a 6mm thick belt. kind of beefy, but Ive seen stuff around that.
4 layers would slide over each other as you bend it, and be better than one 2.4mm thick battery.  So, plausible claims, not totally far fetched.
Offline wraper
  • Country: lv
« Reply #5 on: November 26, 2014, 12:31:10 pm »
Offline ConKbot
« Reply #6 on: November 26, 2014, 05:24:06 pm »
Its missing his pants being around his ankles because the belt went up in flames :-DD
Offline mikerj
« Reply #7 on: November 28, 2014, 01:05:48 pm »
had one of these belts.
Offline Refrigerator
  • Country: lt
« Reply #8 on: November 28, 2014, 04:08:54 pm »
Come on guys, people are trying to innovate. :-+
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline rob77
  • Country: sk
« Reply #9 on: November 28, 2014, 05:15:14 pm »
i would rather prefer a charger built into a backpack than into my belt ;) if my backpack catches fire , then i'll simply drop it... but if the belt catches fire.... well.... i could imagine a better day  :-DD
Offline PlainName
  • Country: va
« Reply #10 on: November 30, 2014, 12:38:10 am »
And yet many people - possibly even you - are happy to shove their phone in the front pocket of their jeans without a second thought.
Offline rob77
  • Country: sk
« Reply #11 on: November 30, 2014, 01:55:47 am »
the phone and it's lithium battery are rigid and the current draw is minimal when the phone is in my pocket... so the risk of catching fire is practically zero... the batteries like to catch fire either during charging, heavy discharging or during mechanical stress/damage.
ok the guys demonstrated the cells are pretty durable - punctured and cut the cell several times in the video.... but they didn't demonstrate the many thousand times bending ;) and actually that's what happening to a belt during wearing  - constant bending during the day... it's not a "single bend" in the morning and then static all day.... it's thousands of changes in the curvature of the bend all day long.
Offline PlainName
  • Country: va
« Reply #12 on: November 30, 2014, 11:34:51 am »
Not quite zero - it has happened more than once. There is some thought that these instances were due to after market batteries, but that's irrelevant to the point that those people shoved their phones down their pants.
More relevant, I would have thought, is that this IGG affair would carry the appropriate test marks (whereas the 'light-up' batteries above probably didn't). As such they would be as safe as original batteries - otherwise they wouldn't pass the tests - so no more likely to burst into flames. If the don't pass those tests then you a) know you're buying rubbish and/or b) they wouldn't be able to complete the project. Either way, if the batteries are a liability they would be in really really deep shit.
I wouldn't worry that the batteries fail catastrophically. I would worry that my money disappears because they can't ship safe batteries.
Incidentally, BBC Click! showed this project over the weekend. They (Click!) tend to be near the bleeding edge but generally don't show hopeless stuff that doesn't have a chance. Not sure if that means anything regarding this project - maybe they got hoodwinked, or they have new and more gullible researchers just joined :)
Offline rob77
  • Country: sk
« Reply #13 on: November 30, 2014, 04:59:01 pm »
agree it's definitely not zero - but the very few cases per many many millions of batteries is "practically zero".
it's like aviation - the chances that the plane you're travelling on will crash is practically zero, but we all know plane crashes do happen sometimes.
so in fact we can consider the rigid phone battery safe (as travelling via airplanes is the safest way of transportation) under the standard circumstances (no overload, no damage from mechanical stress).
