Author Topic: Zero Mass Water  (Read 13707 times)
Offline helius
Re: Zero Mass Water
« Reply #25 on: June 06, 2018, 05:36:17 pm »
I think "it" refers to the seawater.
Water, water, every where,
And all the boards did shrink;
Nor any drop to drink.
But filtering seawater with small hand-powered RO pumps (Katadyn) is probably more practical in many situations.
Offline PlainName
  • Country: va
Re: Zero Mass Water
« Reply #26 on: June 06, 2018, 05:59:21 pm »
Ah. Rereading I see that you are correct :)
Offline Cyberdragon
Re: Zero Mass Water
« Reply #27 on: June 07, 2018, 06:30:38 am »
No, he means the beach water is normally not drinkable.
Also, "regeneration liquid"? :-DD :bullshit: There should only be one liquid...water. Refridgerent is usually gas, so unless that's what they mean it's a load of hoey.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline nuclearcat
  • Country: lb
Re: Zero Mass Water
« Reply #28 on: June 07, 2018, 06:54:16 am »
Some solutions for extracting water from air using brine, so it might be some regeneration fluid for it.
https://www.igb.fraunhofer.de/content/dam/igb/en/documents/sheets/pt/1711_PB-pt-wasserausluft-en.pdf
Offline helius
Re: Zero Mass Water
« Reply #29 on: June 07, 2018, 07:09:11 am »
Ammonia.
Offline CJay
Re: Zero Mass Water
« Reply #30 on: June 07, 2018, 12:33:10 pm »
I think he means there's plenty of undrinkable water that can be made potable by the plastic sheet trick
Offline Cyberdragon
Re: Zero Mass Water
« Reply #31 on: June 15, 2018, 08:05:23 pm »
Ammonia.
Pretty sure that's not allowed anymore. EDIT: In consumer goods and residential that is.
« Last Edit: June 15, 2018, 08:09:46 pm by Cyberdragon »
*BZZZZZZAAAAAP*
Offline exile
Re: Zero Mass Water
« Reply #32 on: July 23, 2018, 08:37:55 am »
What I can see seems to be able to keep what it promises.
I would think it builds absorption technology and uses the Solar thermal collector.
(see )
Solar thermal collector has better efficiency than usual solar panels.
So 1.2x1.2m * 2p * 1000w / m² * 80% ~ 2300w in 5 hours should compile it in 11.5Kwh and suppose it provides about 1L / kwh, then the generara should be 11L / day on a good day.
The solar panel in the middle is for fans and control systems, etc.
If it's worth a price then no. And really dry areas, the function is highly limited.
