Author Topic: Zero Noise, Zero Fumes, GREngine. Zero Engine?  (Read 1329 times)
Offline mbest
« on: October 27, 2018, 07:55:13 am »
Other than a fancy name, it's a portable lithium battery pack?
https://www.indiegogo.com/projects/grengine-an-evolution-in-portable-power
Offline SiliconWizard
Re: Zero Noise, Zero Fumes, GREngine. Zero Engine?
« Reply #1 on: October 27, 2018, 01:03:04 pm »
Yes, with an integrated charger and an AC inverter.
There are so many associated safety concerns that successfully taking this to market for a small team with limited means seems way optimistic.
Offline Cyberdragon
« Reply #2 on: October 27, 2018, 03:17:09 pm »
However, it is a very well established technology, so they probably just copied someone else. ::)
EDIT: Woah, wait, I notice some problems with that chart, the first being they both have the same discharge time, despite one being 3 times more capacity. Also, no balancing on the light model? Seriously? :palm:
« Last Edit: October 27, 2018, 03:27:33 pm by Cyberdragon »
*BZZZZZZAAAAAP*
Voltamort strikes again!
« Reply #3 on: October 28, 2018, 05:29:12 am »
No need to copy really. All the bits and pieces are readily available.
Building a safe product is not a Lego game, though, so they might learn that the hard way. Unless they just disappear with the $80k+ they raised. :popcorn:
