If you want to be pedantic about it, get a water misting bottle and spritz it near to the covered record player 30 or so seconds before you uncover it
Back in the 70's and 80's they used to sell an ionizing gun. Used a piezo crystal to generate high voltage to a needle-sharp point. Actually worked, I ran some experiments and it did reduce the attraction of dust and other lightweight particles to a vinyl LP. None of the mess of a water misting bottle, either! {grin} I still have mine tucked away somewhere, along with my Technics turntable.
I'll say it once again: For some reason audio attracts a unique brand of gullible people. When I was a teenager in the golden years of high end audio, I too fawned over the latest low distortion figures for pre and power amps, etc. Every hundredth of a percentage was important. Then I took a acoustics physics class, during part of which we studied microphones and speakers in an anechoic chamber. We proved that virtually all electromechanical transducers distort several
whole percent, regardless of cost. So no matter how low the distortion in your electronics signal path, you start off with several percent from the microphones and you finish with several more percent at the speakers! The cutting heads for mastering LP's also distorted several percent, as did phono cartridges whether moving magnet or moving coil.
From that day forward I paid more attention to lowering the noise floor (still a passion of mine) than distortion. At least distortion is related to the original signal, while noise is inherently foreign. I don't waste money chasing after the lowest possible distortion, because it literally doesn't matter.
Meanwhile, folks are apparently still buying "oriented speaker cables" and other such audiophool tripe. If I were less honest I could be a whole lot wealthier.
