Author Topic: prove that not all Aliexpress sellers know what they are selling  (Read 836 times)
Offline GreenHW_GUY
  • Hardware Electronic RF Power-electronic
    • included if you specify a URL below.
I was asking the seller to get the right info, because the info on the page was not right, and the answer didn't help me more. You can try to find the error
I Program with Solder
Offline station240
Re: prove that not all Aliexpress sellers know what they are selling
« Reply #1 on: October 14, 2018, 10:14:34 pm »
RG58 is 50ohm (or 52), so either they meant to write RG59, or they got the resistance wrong.
Offline GreenHW_GUY
« Reply #2 on: October 15, 2018, 03:33:39 am »
I know that why I don't get any good info Info from the seller, and all with Coax on aliexpress write the same, when you looking for the 50z \$\Omega\$ COAX, it was only for hobby project, my ham radio I use some highter Quallity Cables
Offline Cyberdragon
« Reply #3 on: October 15, 2018, 05:05:35 am »
They don't use the RJ-59 designation (or at least properly) in China. They mark it based on wire diameter and connector type and not by the impedance standard. So yes, that cable is likely exactly as specified, it really is a 75 \$\Omega\$ RJ-58.
https://www.eham.net/ehamforum/smf/index.php?topic=94343.0
*BZZZZZZAAAAAP*
Voltamort strikes again!
