Author Topic: Probable counterfeit Dallas Semi DS1230 NVRAM on eBay  (Read 3985 times)
Offline precaudTopic starter
    • LinearZ
« on: April 26, 2018, 07:39:57 pm »
I see plenty of signs of bad intent on this and thought I'd share it.
A couple weeks ago I needed a DS1230Y NVRAM for an HP scope. Prices for these things on eBay are all over the map. I wrote several sellers, asking if the date code in their product photos (usually 1990's or 2000's) were what I would receive. All but one said yes. One seller "tube_buyer" said he could send me a more recent one, so I ordered one.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItemVersion&item=361787213071
He created a shipping label the next day, but didn't actually hand the parcel over to USPS until 5 days later. Bad business from the get-go.
12 days after ordering, I received the NVRAM, opened it, and noticed that half of the printing on the top of the case had adhered to the plastic wrap it was packaged in. Suspicion arose immediately that the ink had not dried completely before it was packed. "Sure I can send you a more recent date code". Just print it up.
I desoldered the old one and installed a socket and then the new NVRAM. The scope hung on powerup. Reinstalled the old one again, the scope booted. So the SRAM in the one tube_buyer sent me was defective.
I sent him an email explaining the situation, and asked for a refund. He asked if he could replace it and send me another one instead. I replied, yes, but only under two conditions: 1. You test the one you're sending to verify it is good, and 2. You ship it immediately and don't just generate the label several days before shipping it. He immediately responded that he would send me a refund (which he has not yet sent).
I'm pretty convinced that these supposedly "new" and supposedly "Dallas" NVRAMs are fakes. It looks like he buys them without top labels from an unknown source and prints them up. Want one from 2017? Sure, no problem.
The first photo is of two genuine DS1230's, Notice the "1" moulded in the circle identifying pin 1.
Second photo is the unit I received. See all the ink that came off during shipping.
Last photo is the two genuine 1230s on either end and the fake in the middle. There is no "1" moulded in the circle for pin 1.
At a very minimum, the product is bad and the seller is deceptive. I also think the product is a knock-off. Caution advised.
Offline edpalmer42
Re: Probable counterfeit Dallas Semi DS1230 NVRAM on eBay
« Reply #1 on: April 26, 2018, 07:57:11 pm »
Does the alleged fake unit even have a battery?  If you use a very small magnet, you can trace the outline of the battery.  In the ones I've been able to test, the battery is under the logo.  You can even measure the battery voltage.  Note where the battery is closest to an edge.  Use the magnet to find the point on the side where the battery is closest to the surface.  Drill a tiny hole in the side at that point.  Drill by hand, not with a power drill!  That gives you access to the positive side of the battery.  Negative is the chip's ground pin.
Done carefully, this test has no effect on the operation of the chip.
Ed
    • LinearZ
« Reply #2 on: April 26, 2018, 08:25:03 pm »
Since the SRAM is defective, there's no point in looking into the battery...
Offline Macbeth
« Reply #3 on: April 26, 2018, 10:54:40 pm »
Well, other than documenting the anatomy of a fake which is always useful.
I mean if someone bothered to document your particular SRAM then you would have found it on google and not wasted your time, surely?
    • LinearZ
« Reply #4 on: April 26, 2018, 11:23:43 pm »
I'll wait until I actually receive the refund to do any tearing into it...
Offline edpalmer42
« Reply #5 on: April 27, 2018, 01:32:32 am »
My first guess is that there is no battery.  The magnet will confirm that immediately.
There's a slim chance that the unit is 'real' but has a battery that died long ago.  Remove the original ink and add whatever you want and you've got a new unit with whatever part number and date code you want.  As long as the case is the right size and has the right number of pins, the subterfuge might work long enough to run out the clock on a refund.
Ed
Offline Tomorokoshi
« Reply #6 on: April 27, 2018, 02:14:54 am »
It's counterfeit. Several years ago we got some of those installed in production units. They would hold data for a couple months only. The key distinguishing feature was the silkscreen: the counterfeits had beautiful, crisp, bright white silkscreens compared to the real parts. It was just like that one, except at least they let it dry and the date code was different.
    • LinearZ
« Reply #7 on: April 27, 2018, 02:34:04 am »
Thanks for confirming,Tomorokoshi.
There does appear to be a battery in the unit, a magnet does pick it up on one end of the bottom.
How does he continue to get away with selling these? Well, for one thing, as long as he refunds buyers who complain, he'll never get negative feedback. Issuing a refund cancels the sale and disables the buyer's ability to leave feedback. It's one of the ugly aspects of the eBay feedback system.
Online helius
« Reply #8 on: April 27, 2018, 02:53:18 am »
If the device is truly NOS, it may still hold its charge from 1990. They came with a "freshness seal" that maintained extremely low leakage current until the chip powers up for the first time.
Offline amyk
Offline Tomorokoshi
« Reply #10 on: April 27, 2018, 02:32:05 pm »
Here is the Dallas counterfeit.
It looks like Digi-Key has your part:
https://www.digikey.com/product-detail/en/maxim-integrated/DS1230Y-120/DS1230Y-120-ND/1087557
    • LinearZ
« Reply #11 on: April 27, 2018, 02:49:25 pm »
Yup. Looks the same as the one I got.
I found a DS1230 while scrounging for something else in one of my parts boxes last night. Don't remember how/where it came from, but the leads were clean (it hadn't been soldered in before). I dremeled (is that a legit verb?) enough mat'l away to expose the edge of the battery. It tested 3.1V, so I went ahead and used it. Will run the self-cal on the scope today, check the leading-edge risetime/aberrations, and she'll be ready to roll.
