Author Topic: Zero distortion amplifier  (Read 4752 times)
Offline CirclotronTopic starter
« on: April 18, 2018, 04:52:16 am »
Offline BrianHG
Re: Zero distortion amplifier
« Reply #1 on: April 18, 2018, 05:14:23 am »
 :palm: They have a bass and treble knobs.  Isn't it the whole purpose of these knobs to distort the signal into a sweetened sound?
Offline BravoV
  • +++ ATH1
« Reply #2 on: April 18, 2018, 05:26:01 am »
Q.U.A.Dramatic ... (Q)uite (U)nconvincing (A)nd Dramatic
Offline Cyberdragon
« Reply #3 on: April 18, 2018, 07:06:44 am »
No, bass and treble knobs are just frequency filters. They are not supposed to cause THD. You're thinking of the "English" knobs on guitar amps and such.
EDIT: Their claims are also probably BS. That amp is basic, it somehow has left and right treble, but not even a proper balance comtrol, just a switch! :-DD Why would you even want seperate tone controls for each channel, over a balance control which is more useful! They also have a "contour" switch. What the hell does that mean? That sounds like it would add distortion, which is fine, but don't give it a stupid name! My cheapo old transistor amp has more funtionality than that POS! Oh hell no, out of my sight with that rubbish before my eyes bleed! :--
*burries himself in a box of tubes* "Wake me up when it's gone!"
« Last Edit: April 18, 2018, 07:29:26 am by Cyberdragon »
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline Refrigerator
  • Country: lt
« Reply #4 on: April 18, 2018, 07:37:38 am »
i bet it wouldn't go to 11 without distortion.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
The following users thanked this post: chris_leyson
Offline BrianHG
« Reply #5 on: April 18, 2018, 07:56:36 am »
Tell me, if I feed the amp a perfect 40hz square wave and turn up or down the treble other than having it on a theoretical dead perfect flat setting, will the output not appear to be a distorted version of my perfect square wave source signal?  Note I understand what you are getting at, but when they say ABSOLUTE 0 distortion, they have to mean 0 distortion.  You cannot throw around a figure like that without being serious.  You need to get rid of all the bass, treble, and even balance BS and make a perfectly flat matched channel to channel gain amp with transformerless direct drive to the speaker terminals with proper negative feedback design to correct unusual speaker loads to achieve anywhere near such a claim.  Without a perfect corrected negative feedback at the speaker terminals, to have 0 distortion, wouldn't they have to have created an amp output driver stage with infinity current to deal with the varying impedances and currents over frequency range which come when driving a dynamic load like a speaker?
« Last Edit: April 19, 2018, 10:31:08 pm by BrianHG »
Offline hayatepilot
« Reply #6 on: April 18, 2018, 08:46:12 am »
Maybe the distortion was not measurable with common test equipment back in the day.
They probably couldn't measure below .1%
Then a sleazy marketing person came up with this BS claim of zero distortion. |O
« Reply #7 on: April 18, 2018, 09:10:36 am »
Perhaps you had to plug it in and when you turn it on, the band arrives at your door.  :-DD
The irony of all this is the best recording I have of anything IMHO was recorded on a shitty Tascam minidisc deck using the lowest bidding everything between that and the instruments.
Offline Electro Detective
« Reply #8 on: April 18, 2018, 10:20:14 am »
Zero distortion is when the sound system is switched off, and the power cable unplugged from the wall   :phew:
The following users thanked this post: BrianHG
  • Country: lt
« Reply #9 on: April 18, 2018, 01:05:53 pm »
A simple audio cable also has 0% distortion.
Offline Brumby
« Reply #10 on: April 19, 2018, 12:17:24 am »
Are you sure?
Zero has no wiggle room at all.  Even thermal noise from the wire's atomic structure would be outside the specification.
Offline thermistor-guy
« Reply #11 on: April 19, 2018, 02:27:12 am »
Quotes from the OP's attachments:
"absolute zero distortion"
"actually zero distortion"
"complete absence of any distortion"
I'm picturing a T-shirt. The front says: "The Stupid. It Burns." The back says: "Danger. Highly Flammable. Audiophool inside."
Offline Brumby
« Reply #12 on: April 19, 2018, 04:34:32 am »
Yeah.  This one in particular gives no room for any tolerance.
« Reply #13 on: April 19, 2018, 10:35:31 am »
I wonder how many people bothered to find out, before commenting, that this is a design (and presumably advert) from the early to mid 1960s?
By 1960's standards that "zero distortion" claim is close to pure "truth in advertising" compared to the claims that were made for many products. From what I can find out this was, for the day, a genuinely high quality bit of kit, and they probably couldn't measure the typical harmonic distortion with the instrumentation then generally available. Remember, the contemporary HP 204B sine wave oscillator was specified as harmonic distortion "< 1%".
« Reply #14 on: April 19, 2018, 12:03:01 pm »
Looks like some people didn't believe it back in the day either.
The following users thanked this post: BrianHG, Electro Detective
« Reply #15 on: April 19, 2018, 12:10:53 pm »
Is it just me, or does that "manufacturer's reply" have a passing similarity to the slightly better quality of marketing Chinglish?
Offline BrianHG
« Reply #16 on: April 19, 2018, 10:33:35 pm »
With one forgivable mistake, at the time, the manufacturer assumed that in outer space, there was an absolute 0 temperature.  We know better today.
Offline ebastler
« Reply #17 on: April 19, 2018, 10:44:20 pm »
Does the manufacturer’s reply essentially say „There is enough noise to make the distortion unmeasurable“?  ;-)
« Reply #18 on: April 20, 2018, 08:58:29 am »
Re: Zero distortion amplifier:
An empty amplifier chassis, parked on wet grass or moist ground, on a cloudy day
Not sure what speaker cables will be compatible, an oxygen free variety perhaps
both must be equal length when stretched straight using a hired reference cable
I haven't quite worked out what the source interface will be, most likely the cheapest Audiophool thingie available secondhand,
still saving money for that, maybe I'll mortgage the trailer again...
;D
Offline Harb
« Reply #19 on: April 20, 2018, 09:05:20 am »
You didn't read the fineprint on the other side of the box "Actual Zero distortion was measured during a blackout on a wind free day"
Offline TimFox
« Reply #20 on: April 26, 2018, 09:18:59 pm »
The manufacturer meant "unmeasureable distortion" but did not state that.
When my underlings tried to put "zero" in a specification for a non-integer parameter, I told them that "zero is a pious wish, not a spec".
During a similar era to the advertisements, I measured the distortion of a transistor RIAA preamplifier circuit using a decent Heathkit solid-state decade-switched generator (Bridged-Tee oscillator) and an old Hewlett Packard vacuum-tube distortion analyzer (Wien bridge to null the fundamental).  Connecting the generator directly to the analyzer gave approximately 0.1% THD, within spec for the Heathkit.  Connecting the generator through an attenuator to the preamplifier, which then drove the analyzer, gave approximately 0.07% THD.  Therefore, the amplifier must have had negative distortion.  Of course, the low-pass filtration of the RIAA network was responsible for cleaning up the output of the Heathkit somewhat.
