Author Topic: Advanced board outline in Eagle?  (Read 4804 times)
Offline trevorford
« on: January 10, 2016, 05:05:50 pm »
Hey all,
   I have made a few boards in eagle now but never to specific dimensions, I recently selected an enclosure I would like to build a project in. The datasheet for the enclosure supplies a maximum pcb size. I was hoping someone would be able to give me some tips or point me to a page/video where I could learn about creating more complex board outlines so that I can re-create this design in Eagle.
   Here is a link to the data sheet: http://www.hammondmfg.com/pdf/1553B_BAT.pdf
   Thanks,
   -Trevor
Offline Stupid Beard
Re: Advanced board outline in Eagle?
« Reply #1 on: January 10, 2016, 06:55:12 pm »
You use zero width wires on the Dimension layer to specify the outline. You can use the Miter tool to make the curves.
Generally speaking, you'd rough out the outline using straight lines of the correct lengths as specified by the datasheet. Then you'd use the miter tool to add the correct radius to each line.
You can also stick the outline in a custom component to make it easier to re-use. In that case you'd delete the default outline when you make the new board, then add the custom component instead.
And don't forget to print it out and check the actual physical fit before you spend a bunch of time laying out the board :)
Offline Karel
« Reply #2 on: January 11, 2016, 03:08:59 am »
+1.
I recently made one for the 1553BGY (without the battery).
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
Offline bxh
« Reply #3 on: January 11, 2016, 09:59:01 pm »
You can also draw the outline in CAD, export the DXF and import it into Eagle.
Offline matseng
    • My Github
« Reply #4 on: January 12, 2016, 12:38:35 am »
According to Elecrow you can simply take a bmp and use the import-bmp.ulp to create the "outline" onto layer 46. It will be completely filled - not just an outline but it seems like they accept that as well... I wouldn't dare trying that with another fab though...
http://www.elecrow.com/blog/how-to-design-christmas-pcb-tree/
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #5 on: January 12, 2016, 12:58:31 am »
Set the grid to 10mm with 1mm alt and start drawing straight lines on the dimension layer.
Make sure they are a fully connected.
That is all.
Offline Christopher
« Reply #6 on: January 14, 2016, 06:52:49 am »
Download DXF from hammond, remove all the dims and other crap
Import into eagle on Dim layer
Make and drink a cup of tea in extra the time it would have taken to draw it out by hand  :P!
