Author Topic: Cadsoft EagleCad Tutorials  (Read 6610 times)
Offline Ferroto
« on: June 27, 2011, 12:11:31 am »
I found a decent set of tutorials on eagle cad which will show you everything a beginner would ever need to know when starting off.
Tutorial 1
Tutorial 2
Tutorial 3
Tutorial 4
Tutorial 5
Tutorial 6
Tutorial 7
Tutorial 8
Tutorial 9
Tutorial 10
Tutorial 11
Tutorial 12
Offline Joshua
Re: Cadsoft EagleCad Tutorials
« Reply #1 on: June 27, 2011, 12:34:13 am »
Awesome - thank you!!!  Do you know if he uses the auto router? I don't really care how to use the autorouter but every tutorial I've found uses it. I want to learn the tricks of
Hand routing with the program.
Offline Ferroto
« Reply #2 on: June 27, 2011, 12:55:01 am »
Yes he does manual routing. :)
Offline sacherjj
« Reply #3 on: June 28, 2011, 10:21:10 am »
Auto routers suck.  That is all.
Offline ivan747
  • Country: do
« Reply #4 on: June 29, 2011, 01:40:34 am »
Nothing betas careful hand-routing, unless you are routing a 32-bit parallel bus with 10 control lines and 4 different supply voltages.
Nothing like the smell of rosin core solder in the morning.
"Could you not use some of that crowdfunded $1.5 million to hire a graphic designer who understands perspective?" -Delta
"A soldering station I bought once had a sticker on it that said, I shit you not, 'QENUINE'." -c4757p
Offline olsenn
« Reply #5 on: December 09, 2011, 06:59:48 am »
Just how much difference does routing make on the quality of the circuit? I know with care one can usually reduce the size of the board, which will ultimately save money and make for a more convenient product, but for the actual effect on performance; if it works reasonably well in a breadboard, wouldn't there be no noticable effect on the product (due to auto-router) unless VERY high frequencies are involved?
Offline BloodyCactus
    • Kråketær
« Reply #6 on: March 11, 2012, 01:41:13 am »
thanks for posting this, very handy. Right now I'm trying to read through Build Your Own Printed Circuit Board by Al Williams. Need all the tuts for eagle I can get :)
-- Aussie living in the USA --
