Author Topic: DF782 Package  (Read 2233 times)
Offline Nuno_pt
  • Country: pt
DF782 Package
« on: June 04, 2016, 05:57:40 am »
Does anyone have an Eagle library of MiniCircuits for the DF782 package like PGA103+ or PGA105+?
http://194.75.38.69/case_styles/DF782.pdf and http://194.75.38.69/pcb/98-pl313.pdf
I already try to create myself this on Eagle, but canĀ“t seem to get it right, so I'm stuck at this.
Any help on this?
Nuno
CT2IRY
Offline Karel
Re: DF782 Package
« Reply #1 on: June 04, 2016, 05:39:14 pm »
Here you go.
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
The following users thanked this post: Nuno_pt
Offline Nuno_pt
  • Country: pt
Re: DF782 Package
« Reply #2 on: June 04, 2016, 06:28:20 pm »
Thanks Karel.
Seems that not many people use MiniCircuits components, so the library is empty, with this and other packages types.
Nuno
CT2IRY
Offline Karel
Re: DF782 Package
« Reply #3 on: June 04, 2016, 09:05:33 pm »
Not many hobbyists (apparantly) use this component. It still could be that it's used a lot by professionals because they tend
to create their own libraries, which is really very easy with Eagle once you get used to it and when you use Eagle daily.
Online blueskull
  • Country: cn
  • Power Electronics Guy
Re: DF782 Package
« Reply #4 on: June 04, 2016, 09:09:32 pm »
Looks like SOT89, will a SOT89 package work?
Offline Karel
Re: DF782 Package
« Reply #5 on: June 04, 2016, 10:13:32 pm »
Actually, I took a SOT89 footprint which I made some time ago and modified it to create the DF782 footprint.
Maybe a SOT89 footprint will be fine, depends on the pcb requirements.
