Author Topic: Does Anyone Know a Good Rotary Encoder Library?  (Read 4986 times)
Offline nathanpc
  • Country: br
    • Innove Workshop
« on: June 10, 2013, 11:53:28 pm »
Does anyone know a rotary encoder EAGLE library that contains the Bourns ECW1-J or any other with a similar footprint?
Offline airiclenz
    • Airic Lenz
Re: Does Anyone Know a Good Rotary Encoder Library?
« Reply #1 on: June 11, 2013, 12:13:25 am »
...most likely you goggled this already and found nothing. This means, there is a very high chance this specific footprint is not available for download as an Eagle library...
So what is wrong with creating the package on your own?
Cheers,
A.
Offline nathanpc
  • Country: br
    • Innove Workshop
« Reply #2 on: June 11, 2013, 01:23:27 am »
Yeah, I've googled for a hour without any success. I just wanted to know if anyone had done it already before attempting to create my own for the first time (since I'm a bit worried about screwing everything up).
Offline c4757p
  • adieu
« Reply #3 on: June 11, 2013, 02:15:57 am »
If you are worried you will do it wrong that means you should practice, not avoid it for longer.
Offline FrankBuss
    • Frank Buss
« Reply #4 on: June 11, 2013, 05:15:02 am »
In an hour your would have created your own library. It is only 3 pins and 4 holes.
Offline nathanpc
  • Country: br
    • Innove Workshop
« Reply #5 on: June 16, 2013, 04:48:26 am »
Sorry, I forgot to post the footprint I made. Here it is if anyone wants it: https://github.com/nathanpc/leafSupply/blob/master/Custom%20Stuff.lbr
Offline stryker
« Reply #6 on: July 04, 2013, 08:51:38 am »
Thanks, just grabbed it.  Did that version work out okay once you had your board made?
Geoff
Offline nathanpc
  • Country: br
    • Innove Workshop
« Reply #7 on: July 04, 2013, 08:56:16 am »
I tested it using a 1:1 paper print so it should work perfectly on the final PCB. I'm still waiting for my PCB to arrive.
