Author Topic: Doubt in seeing the dimension of the component in the datasheet  (Read 1110 times)
Offline electrowhiz
  • Country: in
The dimension in the datasheet is given with the comma and what it represents? I have attached the image. Tanq in advance
Offline rachaelp
Re: Doubt in seeing the dimension of the component in the datasheet
« Reply #1 on: June 05, 2018, 08:14:57 pm »
In some places it's common notation to use a comma as the decimal point rather than a full stop. In this case I would say your pad width is 0.50mm, pad height is 1.10mm and your pad pitch is 1.00mm.
Best Regards,
Rachael
I have a weakness for Test Equipment so can often be found having a TEA break (http://www.eevblog.com/forum/chat/test-equipment-anonymous-(tea)-group-therapy-thread/)
The following users thanked this post: electrowhiz
