Author Topic: Eagle 6.4 How to rename these (hidden) attributes ?  (Read 959 times)
Offline Kjelt
« on: September 18, 2018, 06:22:49 am »
I thought lets put a nice frame around my schematic.
Although it is in German ( I can live with that) I am totally unable to fill in the fields.
In the attributes just a couple of them are listed the rest is inaccesible ?  :-//
Any ideas hints ?
Part is (RAHMEN_A4_8Z-19S_SPS).
Thanks
Offline Karel
Re: Eagle 6.4 How to rename these (hidden) attributes ?
« Reply #1 on: September 18, 2018, 04:30:39 pm »
I made my own frame based on another one from the library. It's actually very easy.
Once you copied the frame/library and renamed it to something new, you open the frame in the device editor.
Than you open the symbol (the actual frame) in the symbol editor. Now make the changes you want.
There are some predefined words that will be automatically replaced by Eagle with actual data like:
>DRAWING_NAME       (filename)
>LAST_DATE_TIME       (date/time when the file has been modified)
>SHEET         (sheet number)
For example, if there's written (in the symbol) "Sheet: >SHEET" (without the quotes),
then, after adding the frame to the schematic, there will be written "Sheet: n" where n is the sheet number.
After adding the frame to your schematic, you fill in the empty boxes with text strings.
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
The following users thanked this post: Kjelt
Offline Kjelt
« Reply #2 on: September 18, 2018, 04:56:00 pm »
That would be a good alternative  :-+
