Author Topic: Eagle help  (Read 3642 times)
Offline SuperMiguel
Eagle help
« on: November 17, 2010, 04:23:43 pm »
My first eagle project, trying to make a tic tac toe PCB:
Here is what i want: (the lines were made using mspaint)
And here is what i have:
I been trying for a while and can get it the way i want :(
Offline TheDirty
Re: Eagle help
« Reply #1 on: November 19, 2010, 12:32:19 am »
Sometimes you just can't route it single sided and need jumpers. Upload the .sch and .brd files and I'll see how far I can get with it.
Mark Higgins
Offline Waifian
Re: Eagle help
« Reply #2 on: November 19, 2010, 04:45:52 am »
How do you plan to control each LEDs output? In eagle you have to use nets not wires.
Offline TheDirty
Re: Eagle help
« Reply #3 on: November 19, 2010, 05:05:05 am »
You can see the airwires in his screen cap, he's netted everything, he just need to route it all.
Taking a look at it quickly, do you mind of the 'red wire' leds are turned around?  You might be able to route everything if they are turned around 180.  You just have to remember when placing the components that those LED's are backwards.
Mark Higgins
Offline tyblu
    • blog.tyblu.ca
Re: Eagle help
« Reply #4 on: November 19, 2010, 05:48:38 pm »
I gave it a go, and barely got it on a single side.
http://www.ualberta.ca/~tlucas/misc/demo_LEDtictactoe.pdf
http://www.ualberta.ca/~tlucas/misc/demo_LEDtictactoe.zip
You'll want to clean it up or redo it, but it's possible. ;)
Tyler Lucas, electronics hobbyist
Offline vimark
Re: Eagle help
« Reply #5 on: November 24, 2010, 07:12:14 pm »
Have it autorouted and it might give you a hint on the routing, Just a suggestion.
Offline TheDirty
Re: Eagle help
« Reply #6 on: November 25, 2010, 12:32:13 am »
That was really well done Tyblu.
I think it would be easier if the odd LED was turned around 180 degrees, but since the OP hasn't come back to this thread I'm not going to give it a try.
Mark Higgins
Offline Slobodan
  • Banned!
  • Country: cs
Re: Eagle help
« Reply #7 on: August 25, 2011, 02:08:16 am »
Could someone provide me with a link for downloading MCP73871.lbr (QFN20) and BQ24210.lbr (WSON10)?
I could not find it on the internet, and i can't make those footprints in Eagle because i suck at software and i hate software.
EDIT: I have found MCP73871.
« Last Edit: August 25, 2011, 02:44:38 am by Slobodan »
