Author Topic: Eagle: Strange name for GND signal (on two sheets)  (Read 1434 times)
Offline adrifromhh
« on: September 02, 2018, 10:06:33 pm »
Hello,
can you explain to me what's happening here?
The GND Signal is present on two schematic sheets and today I noticed it displaying a strange name in the label. When I click on it with the NAME tool, it just displays "GND". Do I have to worry?
Best,
Adrian
Online H.O
Re: Eagle: Strange name for GND signal (on two sheets)
« Reply #1 on: September 02, 2018, 10:20:05 pm »
Except perhaps for the ??-marks it seems normal to me but I haven't been using EAGLE snince they Went subscription so my memory might fail me. Those baloons are cross-references so they're telling you where the "other end" of that net can be found, Sheet 1, Row 4, Column A or whatever.
Offline Karel
« Reply #2 on: September 02, 2018, 10:36:27 pm »
You should connect pin C3 to a GND symbol like in the other sheet.
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
Offline adrifromhh
« Reply #3 on: September 03, 2018, 06:23:47 am »
Isn't it sufficient to have the signal named GND?
Okay i testet and found out that the strange extension to the signal name comes when the same signal is present on two sheets. When I deleted sheet 2, the label said "GND" again.
I find this way very confusing and annoying especially in this case where only on sheet 1 are the items I want to pe printed to a PDF.
« Last Edit: September 03, 2018, 06:27:12 am by adrifromhh »
Online H.O
« Reply #4 on: September 03, 2018, 02:47:51 pm »
Well, then turn off the cross-reference feature.
Change -> Xref -> Off, click on existing label or place new ones.
Offline adrifromhh
« Reply #5 on: September 03, 2018, 11:41:28 pm »
Okay, I didn't know that "Xref" changes more than just the appearance of the label. Thanks
Online maginnovision
« Reply #6 on: October 01, 2018, 02:16:17 pm »
You can also set up your XREF labels. I usually set it to just the signal name and sheet. I don't use grids much so it's cleaner than ?? every time.
