Author Topic: How to edit pin numbers in eagle cad (newbie question)  (Read 9560 times)
Offline DarkZero
  • Country: cs
« on: May 15, 2012, 12:05:30 am »
i wanted to edit one component to suit my need but i just cant get those pinout to show numbers i want this program is seriously hard to learn if u don't ask around
Offline baljemmett
Re: How to edit pin numbers in eagle cad (newbie question)
« Reply #1 on: May 15, 2012, 12:22:02 am »
I think pin numbers are shown if you have the 'visible' field for the pin (in the symbol editor) set to 'pad' or 'both'.  The 'pin' setting will just show the name of the (symbol) pin at the inside end of the pin, whereas the 'pad' option shows the name of the (package) solder pad/pin alongside the pin.  If you follow me, ugh.
Offline DarkZero
  • Country: cs
« Reply #2 on: May 15, 2012, 03:25:06 am »
thanks !
ill try it out
EDIT: it works ! thanks again
« Last Edit: May 15, 2012, 06:26:50 pm by DarkZero »
