Author Topic: how to make circular board with flat edge for usb  (Read 1932 times)
Offline buck converter
« on: August 08, 2017, 12:06:13 am »
something like this:
Just me and my scope.
Offline jct
    • R&D
Re: how to make circular board with flat edge for usb
« Reply #1 on: August 08, 2017, 07:11:28 pm »
Use "Dimension" layer and draw straight line, then use Arc function to draw circular section to connect with previously drawn straight line.
« Last Edit: August 08, 2017, 07:18:18 pm by jct »
Pain is temporary, giving up is forever.
The following users thanked this post: buck converter
Offline jpanhalt
« Reply #2 on: August 08, 2017, 07:16:21 pm »
Another alternative is to draw what you want in a CAD program.  Save as DXF, and then use the import-dxf ulp to import into EAGLE dimension layer.
While a circle with a flat edge is not complicated, for more complicated shapes I fine the above process easier.
John
« Reply #3 on: August 09, 2017, 02:47:30 am »
